Lots of engine heat!
Old May 25, 2010 | 07:32 PM
vitaminZ's Avatar
I realized these cars build up a lot of heat under the hood, anyone know how to solve this..or even a solution to keep it cooler?
thanks
Old May 25, 2010 | 08:07 PM
300zgearhead's Avatar
It's called an engine, it creates heat. If your temp reads normal then there's nothing to worry about.
Old May 25, 2010 | 08:58 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Yeah, the VG30DE(TT) is just a hot-running engine... not much you can do about it.
Old May 26, 2010 | 03:01 AM
KasbeKZ's Avatar
Pr0n Addict
and it's a fairly big one packed into a fairly small space. this is why FMIC's are not a good idea. we need all the air flow we can get.
Old May 26, 2010 | 12:01 PM
Remove hood. Problem solved.
Old May 26, 2010 | 08:19 PM
vitaminZ's Avatar
haha, sorry. I might just rig up some 3 piping into the engine bay from behind the front bumper to help cool it down.
Old May 27, 2010 | 03:31 AM
Sam's Avatar
Sam
VitaminZ, what do you mean by "rig up some 3 piping into the engine bay" ???
Btw my temp reads normal however when i open the hood i hear water boiling inside the radiator sometimes...
Old May 27, 2010 | 07:39 AM
domsgarage's Avatar
Tough Guy
just pack that bitch with some ice.
Old May 27, 2010 | 09:41 AM
nismo619's Avatar
HOOD SCOUP ! HOOD SCOUP !!! im useing a stock z31 hood scoup on my my 93 300zx keeps the engine nice and cool. bad side if it rains ...
Old May 27, 2010 | 02:20 PM
KasbeKZ's Avatar
Pr0n Addict
fyi, none of that stuff helps. running a little cool air around the engine isn't what helps. upgrade your oil cooler if anything, but the air around the engine is just always going to be hot, because whether or not you introduce a flow of air from the top or from the front, there's really no where for it to go. you're not sucking heat out of your block by putting a fan on it.
Old May 27, 2010 | 02:53 PM
Hood scoops don't cool an engine bay off. Hood vents do. What you're experiencing is called a "placebo effect."
In fact, hood scoops on cars that don't have an intake behind them has it's own term... it's called "rice."
Old May 27, 2010 | 08:30 PM
vitaminZ's Avatar
I understand it will be hot, but i hate all that heat under the hood. The temp does read normal but all that engine heat can really take a toll on the wiring and other parts.
And as for rigging up..in my 89 Supra it had a nice route from the front grill to the engine bay so i got some 3'' flex pipe and just ran that up..it helped bring air to my intake..because the supras intake sits beside the timing cover/turbo, and have no direct air supply, just all engine heat.
As i look closely at my engine it would be a task to find a route..ill find one/
Old May 28, 2010 | 07:59 AM
So we can all say "I TOLD YOU SO" later, before doing any modifications, take some data:
-=Use an infrared thermometer=-
-Outside ambient temp
-Temp under hood when engine is cold
-Temp under hood when engine is hot
-Temp of hood when closed / engine hot
After your modifications:
-Outside ambient temp (hopefully the same as before)
-Temp under hood when engine is cold (same spot on motor)
-Temp under hood when engine is hot (same spot on motor)
ol55
Dec 17, 2013 02:36 PM
J-cubZ
Sep 10, 2010 03:19 PM
FubarI33t
May 29, 2010 09:05 PM
drftrzx
Sep 11, 2008 09:02 PM
nuzxowner
Feb 13, 2005 06:38 AM
