help! lotsa water in the air ducts...
Old Oct 14, 2003 | 12:17 AM
Riz Z Speed's Avatar
Administrative Brown Guy
http://www.twinturbo.net/ttnettech/aiv/aiv.html
have fun
Old Oct 31, 2003 | 06:26 PM
JohannB's Avatar
RE: water in the ducts
My '90 Z had the same problem My A/C drain was clogged and it had a half quart of water in the A/C compartment air box. Look under the A/C box and pull the rubber hose off. It will be hard to get to but you can do it. Stick a piece of wire or small tubing into the drain and wiggle it around.
Have a large towel under the unit because you are gonna have a small flood when the drain clears out. Finally, blow out the drain hose and you should be good to go.
Johann
280zForce
Jun 1, 2011 10:19 AM
702Fairlady
Oct 18, 2006 08:34 AM
duowing
Oct 18, 2005 11:15 AM
fuego305
Nov 6, 2004 11:13 AM
auxilary
Feb 1, 2004 07:37 PM
