good electric fan?
Old Mar 29, 2009 | 10:18 AM
FnF.Z's Avatar
good electric fan?
https://www.zdriver.com/forums/images/smilies/102.gif does anyone know where i can find a good electric fan for my '90 NT 300zx? the one on there now sounds like a hurricane under the hood. if anyone could let me know where i can find a good one for cheap please let me know.
Old Mar 29, 2009 | 08:42 PM
napoleonzheking's Avatar
F5 Hero
return to stock clutch fan...
Old Apr 12, 2009 | 07:53 AM
FnF.Z's Avatar
why? is the stock fan that much better than an electric? i just want it to be quiet, effective, and maybe free up some hp in the procces. do you think my fan is shot since its always on full speed?
Old Apr 12, 2009 | 09:34 AM
jrealmuto1's Avatar
i run a one on my z and runs alot cooler than i though it would and it frees up space...
Old Apr 12, 2009 | 11:16 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
The stock fan is *widely* accepted as far superior to any electric fan on the market. And any horsepower that an electric would free up is negligible at best.
And omg at your screen name. Are you kidding me? And I truly hope that's not your car in your avatar.
Old Apr 12, 2009 | 12:07 PM
KasbeKZ's Avatar
Pr0n Addict
the stock fan moves an amazing amount of air. running the car over some grass or a sandy spot of road will show you that. it's a pretty amazing fan. the downside being that if you don't live in the city, you end up having to clean out the shroud and radiator once in a while, because if you drive down a messy dirt road while it's dry outside, it picks up a lot of stuff because of all the air it moves.
Old Apr 12, 2009 | 12:35 PM
The_MuffinMan25's Avatar
Registered Drifter
Ford Taurus SHO Electric fan (SHO is slimmer any V6 fan will do tho), Toyota MR2 Electric fans I've been told work well, I assume anything mid/rear engine will have a sufficient E-Fan. You do have a Non-Turbo Z so you probably have less heat in your engine bay and run a lil cooler in general compared to a TT.
Also find a site that specializes in Z's and look for E-Fan kits. I assume as long as it's from a well recommended and known "good" Z site that they will be selling a quality kit.
(Only reason I'd consider one is to get rid of that clutch fan noise, yuck!)
Old Apr 12, 2009 | 01:06 PM
KasbeKZ's Avatar
Pr0n Addict
clutch shouldn't make any noise if it's in good shape. hey make noise when they are wearing out. mine is silent. or do you mean the sound of the fan actually moving the air?
Old Apr 12, 2009 | 05:33 PM
Registered Drifter
The air....as in you rev up your engine at a stop and you hear air more than you hear your engine
Old Apr 12, 2009 | 05:34 PM
Get a louder exhaust.
Old Apr 12, 2009 | 06:52 PM
KasbeKZ's Avatar
Pr0n Addict
^^ lol that's what i was going to say. i've never heard that.
Old Apr 12, 2009 | 07:08 PM
F5 Hero
i've never heard my clutch fan.
Old Apr 12, 2009 | 08:44 PM
Registered Drifter
Well 3" Downpipes & testpipes should help out
Old Apr 17, 2009 | 10:28 PM
FnF.Z's Avatar
yeah, i hear the air more than the engine not the fan itself. i herd permacool and flex-a-lite are good E-fan companys. its non turbo. and what is wrong with my sn an avatar? honestly i dont care what my sn is. im not gonna spend an hour trying to figure one out thats not taken juss to i can talk on a forum. i would put "ljakshfouhyfa" if i could remember it. also would it be bad if i replaced the front grill with a mesh? ive seen some with it completely removed. but i think if its raining the air filter could get wet an nasty. juss throwin it out there..
Old Apr 18, 2009 | 08:25 PM
F5 Hero
I heard if i put my finger in my butt hole and massage my prostate it makes my male orgasm last longer and *** with more "oomph".... I'm still probably not going to do it. Like everyone (including myself said), stay with a clutch fan..... That's what we recommend. If your going to go eletric anyways, then just get one, because none of us have a clue because we stay with clutch fans because they out perform eletric fans, and a hot motor something none of us who love our Z's want.
Z's have grills?!?!?!?!
Old Apr 18, 2009 | 08:27 PM
F5 Hero
I was not trying to be a butt hole btw. just saying.
Old Apr 23, 2009 | 11:30 AM
DropTopTwin's Avatar
I learn new stuff on this site all the time but better orgasms through your butt? Who figured that out? Lol.
Old May 16, 2009 | 08:51 PM
Goofyz's Avatar
To answer the question
Flex-A-Lite makes a couple options for the Z32. I assume you already put in the Koyo or similar radiator? There is a benefit to nearly doubling the cooling capacity of the Z.
Upside:
You no longer need to move so much air. The other benefit is since there isn't as much weight or torque on the water pump shaft the bearings tend to last a bit longer.
Downside:
When electric fans wear out they usually just stop and you won't know until you happen to see the temp gauge climb. So replacing the fan motor should become part of the routine maintenance schedule.
Neutral:
You can set the electric fan to run after the car is shut off for further cooling. Yes the stock fan moves more air whenever the engine rpm is above a certain point, but not at idle, the electric moves more air at idle and yes at 1200 rpm too (with A/C kicking on). After 2500 rpm the stock fan moves more air.
With the double width radiator the stock clutch fan comes awfully close and you really can't use the air guides (stock shroud) without shaving them down, a real pain in the *** btw. A good electric fan will come with a shroud.
Old May 17, 2009 | 01:40 AM
FnF.Z's Avatar
thank you, for answering my question and helping with my prob. unlike some of these haters. and after 2500rpm the amount of air the fan moves doesn't matter as much, most likely your gonna be moving anyway. i've herd good things about flex-a-lite. however i have not put in a koyo or similar radiator. also im thinking about taking out my ac condenser an fan, the fan is seized up and the wires are cut and corroded for some reason. but thats another thread somewhere. thanks again for the positive feedback
Niku-Sama
Sep 28, 2008 12:32 PM
skupy
Nov 14, 2005 01:42 PM
antisub
May 15, 2005 02:57 PM
Las VegaZ
Aug 31, 2004 04:00 AM
zkyle
Mar 20, 2003 09:55 AM
