Frustrating PS Belt Squeal HELP!!
Old 03-04-2023, 12:20 PM
Bennyh's Avatar
Hey everybody thanks for looking at my post. Well im stumped, i have a 94 300zx NA. Brand new PS pump, belt, pulley. When I first installed these components the vehicle was quiet. But after a few days on cold start I get the horrid belt squeal. Sounds like its coming right at pump. I have tried tightening belt, loosening belt, new belt, super clean my pulleys, checking pulley bolt for tightness, adjusted the slider. On top of the cold start squeal it will go away after about 2 minutes. However this is where it gets odd. If I roll my windows down belt starts chirping, if I turn up stereo system with subwoofers it starts squealing. So anything power related causes a chirp or squeal, if I drive it will start squealing randomly. I tried taking off PS belt as since it happened with power components in use in car I thought it was alternator belt. But it does not squeal when the PS belt is off. I am stumped do I need a new pump? Pulley? Water Pump pulley? Any help would be great fellas thanks.
Bennyh is offline
Old 03-10-2023, 08:02 PM
FlyingT's Avatar
It is your alternator that is squealing. Putting a large draw on the electrical system forces the alternator to have to create more power and that causes more drag on the belt.
FlyingT is offline
Old 04-09-2023, 08:50 PM
Bennyh's Avatar
Hey FlyingT thanks for the reply honestly I did not think it was alternator since I ran car without Ps belt and no squeal. But it would make sense seeing as how the belt will squeal when a power load is happening and it’s so hard to tell since the alternator is right below the Ps pump. But I think my next move is put a high output alternator on and new belt and see how that goes. I’m starting to be convinced it’s the alternator and or alternator belt. Thanks again for the reply, when I make the swap I’ll report back.
Bennyh is offline
N300zx89
04-22-2014 07:14 AM
OutlawZ
08-10-2011 07:28 AM
vitaminZ
03-31-2010 01:38 PM
ezramoore
01-26-2007 01:31 PM
mavezx
08-19-2002 09:21 PM
Quick Reply: Frustrating PS Belt Squeal HELP!!
