Exhaust Smoke
Exhaust Smoke
Usually when im accelerating into 2nd gear, you can see smoke from the exhaust. its not blue. you can often smell it inside the car. on high revs smoke also comes out. so im wondering if this is normal ? i had asked a friend about it, and he suggested it get re-tuned or have the ecu re-checked, but im not sure. any idea ? thanks.
How many miles are on z motor? Higher rpm smoke is usually a sign of compression blow-by past the rings. This blow-by stirs up the oil in the crankcase which is carried up thru the pcv valves and back thru the intake where it burns during combustion. This is normally a sign that your motor is getting worn out and it will get progressively worse. Keeping fresh oil in the motor and maybe running a heavier weight oil will help for a while.
One of the tricks to eliminate some of this smoke is to run an oil "catch can". You run the lines from the pcv valve to the catch can instead of back thru the intake.
http://store.summitracing.com/defaul....asp&x=44&y=14
its got 146K on it. so my engine doesnt have much left ? if so, whats the best solution ? i dont want to be driving it one day, and have it cut off on me
Originally Posted by Seraphic
its got 146K on it.
If the blow-by is the cause of the smoke, doing a simple compression test would confirm or deny the theory. Blow-by is a sign that your piston rings/pistons and cylinders walls are getting worn which would result in low compression numbers.
I'm sure there are other people with ideas too.........
im in the saving up progress cause my shopping list is already built and proven to work very well all put together.
yah I'm using a front clip this is my shoppign list.
Front clip,
Electronic boost controler
Turbo timer
engien rebuild gasket kit.
new engine Harness
Ashspec ECU upgrade.
60K mile Maintenance
Tranny flush
Dif flush
COZ Brake kit. (rotors, pads and lines)
AC recharge
New paint (i'm doing the bodywork [shaved my rear wiper])
HKS Hyper Ti Exhaust. and Test pipes.
lucky to have arround 400ish
and arround $6000.00 torn off my pockets.
Front clip,
Turbo timer
new engine Harness
Tranny flush
Dif flush
AC recharge
dave90300zxTT
13
Jun 10, 2015 02:16 PM
Niku-Sama
Aug 29, 2008 08:23 PM
