Exhaust Smoke
Old Mar 24, 2005 | 01:55 PM
Seraphic's Avatar
Loves The Asian Chicks
Exhaust Smoke
Usually when im accelerating into 2nd gear, you can see smoke from the exhaust. its not blue. you can often smell it inside the car. on high revs smoke also comes out. so im wondering if this is normal ? i had asked a friend about it, and he suggested it get re-tuned or have the ecu re-checked, but im not sure. any idea ? thanks.
Old Mar 25, 2005 | 08:50 PM
Seraphic's Avatar
on another note, it also feels a little under-powered. like bogging down
Old Mar 25, 2005 | 08:56 PM
bardabe's Avatar
Bad Speller
oh oh thamn check your motor il and hope there is not water on it. or any oil in the Radiator fluid. make sure head gasketz are good.
Old Mar 26, 2005 | 07:04 AM
CanyonCarver's Avatar
Jack Of All Trades
How many miles are on z motor? Higher rpm smoke is usually a sign of compression blow-by past the rings. This blow-by stirs up the oil in the crankcase which is carried up thru the pcv valves and back thru the intake where it burns during combustion. This is normally a sign that your motor is getting worn out and it will get progressively worse. Keeping fresh oil in the motor and maybe running a heavier weight oil will help for a while.
One of the tricks to eliminate some of this smoke is to run an oil "catch can". You run the lines from the pcv valve to the catch can instead of back thru the intake.
http://store.summitracing.com/defaul....asp&x=44&y=14
Old Mar 26, 2005 | 08:11 AM
Seraphic's Avatar
its got 146K on it. so my engine doesnt have much left ? if so, whats the best solution ? i dont want to be driving it one day, and have it cut off on me
Old Mar 26, 2005 | 08:16 AM
b300z's Avatar
caught the z fever
dang, that sux man. i hope it is something else.
Old Mar 26, 2005 | 08:40 AM
Jack Of All Trades
Originally Posted by Seraphic
its got 146K on it.
I wouldn't say it doesn't have much left. I was trying to say what one of the causes of high rpm smoke is. And a possible cure. It's not like it'll just cut out on you. It's more like a gradual thing. It'll start to smoke more and more over time. 146k miles is pretty low actually, but you never know how it's been maintained.
If the blow-by is the cause of the smoke, doing a simple compression test would confirm or deny the theory. Blow-by is a sign that your piston rings/pistons and cylinders walls are getting worn which would result in low compression numbers.
I'm sure there are other people with ideas too.........
Old Mar 26, 2005 | 03:22 PM
bardabe's Avatar
Bad Speller
pffft Just go TT already. first excuse to do so. start saving up and knock em hard. im in the saving up progress cause my shopping list is already built and proven to work very well all put together.
Old Mar 26, 2005 | 04:04 PM
Seraphic's Avatar
if i had the money i would, but yea, i do plan on saving to get a front clip. and most likely, ill need tons of help doing the conversion
Old Mar 26, 2005 | 05:15 PM
bardabe's Avatar
Bad Speller
yah I'm using a front clip this is my shoppign list.
Front clip,
Electronic boost controler
Turbo timer
engien rebuild gasket kit.
new engine Harness
Ashspec ECU upgrade.
60K mile Maintenance
Tranny flush
Dif flush
COZ Brake kit. (rotors, pads and lines)
AC recharge
New paint (i'm doing the bodywork [shaved my rear wiper])
HKS Hyper Ti Exhaust. and Test pipes.
lucky to have arround 400ish
and arround $6000.00 torn off my pockets.
Old Mar 26, 2005 | 06:27 PM
Seraphic's Avatar
got some good sites or places that sells tt clips with low mileage ?
dave90300zxTT
13
Jun 10, 2015 02:16 PM
Samurai-Z32TT
Jun 25, 2011 07:59 AM
Dgk910
Nov 11, 2010 02:06 PM
Niku-Sama
Aug 29, 2008 08:23 PM
rngrck
Jul 22, 2003 09:55 AM
