Engine swap suggestions
Okay guys I have a 1990 300zx. The stock motor isn't completely gone but I don't think I want to go through the hastle of rebuilding it. So instead i'm thinking about swapping in a v8..I know the vh45 is a pretty popular swap for these cars but I wanted to know what other options are out there? How reliable are the vh45 motors and what kind of power can they handle? I originally wanted a ls swap but they are a little bit out of budget right now..So throw out your opinions!
Welcome to ZDriver!
Endless options. It all depends on your skill level and budget.
http://en.wikipedia.org/wiki/Nissan_VH_engine
It only puts out 278hp / 292ft/lbs torque. It's built like a mother-trucker because it's for the SUV... so it COULD handle more hp (which costs $$$). But 278hp flywheel is A LOT of work, for little increase of power.
So... what is your budget?
VG30DETT
2JZ
RB26
Supercharged LS7
I could name every high-hp engine known to man... kinda hard to tell you what motor to swap into YOUR car... especially without knowing your budget or skill level.
VG30DETT
2JZ
RB26
Supercharged LS7
Welcome to ZDriver!
Thanks bud!
Nissan VH engine - Wikipedia, the free encyclopedia
Do you know how much hp/tq they will hold before they need to be forged? It will end up being rebuilt anyway, but just trying to plan things out!
I have about 2k to spend on a motor but the cheaper the better. The actual swapping/fabricating will be taken care of, i just need to figure out what motor will be the best for me.
VG30DETT
2JZ
RB26
Supercharged LS7
Thanks bud!
VG30DETT
2JZ
RB26
Supercharged LS7
Haha i'm trying to stay away from the turbo motors but its still an option..Every turbo motor i had (redtop sr20, turbo ka24, and now this vg30) just didn't seem to want to stay running. Like i said, my first choice is an ls motor. But they are pretty expensive for a full swap..Anyways, thanks for the reply!
Dollar for dollar, there is rarely a cheaper way to make hp than by turbocharging. I suggest doing research... real research. There are plenty of websites and books / ebooks in pdf that go into great detail about making reliable power.
The ideal motor swap is the VG30DETT (actually, the "real ideal" is to just start with a Z32TT)... because it's already designed for the Z32. Stuffing in any other engine will also require modifications like steering, suspension, motor mounts, transmission mounts, a/c, wiring, etc. If you're up to that and have the time and $$$, get on it!
No clue on "how much it will hold". That's relative to "what it is holding up to".
Turbocharged motors have [require] tighter tolerances than n/a motors because they have to endure more pressure & stress. Since you are apparently going to rebuild any motor you choose, why not just start with a strong turbocharged base?
Z32Z33
Mar 24, 2012 02:51 AM
Fast240Z
Nov 21, 2005 10:31 PM
smokingzcar
Dec 5, 2002 07:57 AM
