fix 81 zx engine or swap engine for more power????
Old Dec 1, 2002 | 09:27 PM
Skully's Avatar
Re: fix 81 zx engine or swap engine for more power????
you can fix it or find a nice turbo l28 and drop it in and yes engines are interchangable...
Old Dec 1, 2002 | 10:22 PM
The 81 turbo engine has a lot more to it than just the block and head. Go ahead and replace your head gasket. That is fairly easy to do. Swapping engines (especially with a turbo) seems like way too much work just to fix a blown head gasket. A 240Z engine would not be good. They are a smaller bored engine and use carbs. You'll want to stick with a 1975-83 block/head if you plan to swap engine blocks to fix your problem. You can change the head gasket in a day and then think about the turbo swap for a later project.
Old Dec 3, 2002 | 02:33 PM
hehe.. I don't fear them, I avoid them. Less power, less fuel economy and illegal to run on an 81 ZX in my area. It won't pass emissions.
Old Dec 4, 2002 | 10:44 AM
yes, that is true. It takes a little more knowledge of the fuel injection to modify them for higher rpm power. I suppose most people who build an engine with fuel injection use the stock fuel setup with a modifed engine. Maybe I should try building a fast n/a 240Z with fuel injection just to see if it works as well as I think it will. That would be a good discussion for another topic.
Old Dec 4, 2002 | 08:19 PM
Like a large tube with flared intake runners and a big throttle body. Also a computer designed to get information from vaccume sensors instead of an air flow meter so your air intake is wide open. That's kind of what I had in mind...
Zedsdead
18
Jan 26, 2015 10:02 PM
sion
May 25, 2006 08:11 AM
SpeciallySpiked
Apr 16, 2006 10:15 PM
shsay
Sep 11, 2004 08:51 AM
emnm
Dec 1, 2002 03:09 PM
