detonation sensor
Old Mar 13, 2006 | 09:24 PM
MO1's Avatar
MO1
detonation sensor
Hey Guys
Got detonation sensor code and correct me if I'm wrong, it's the 2 wire conector near the firewall. The wire from the harness end is busted off. Any tricks to get around it?
Thx
Mo
Old Mar 13, 2006 | 10:02 PM
japanz's Avatar
No, replace the connector. That is the way it should be repaired.
Old Mar 13, 2006 | 11:31 PM
Riz Z Speed's Avatar
Administrative Brown Guy
no tricks, this isn't a magic show.
seems like a simple repair, why don't you wanna fix it?
either you fix it or you don't, there's no tricks to it.
Old Mar 13, 2006 | 11:45 PM
entropy31's Avatar
The Cake Is A Lie!
http://www.angelfire.com/geek/vg30de...tSenRel01.html
btw: i found this in like 20 seconds wth the forum search function.
Old Mar 14, 2006 | 04:42 PM
Aphrodite's Avatar
you also might want to check and see if its the wiring or the detonation sensor.
http://www.300zx.co.uk/cgi-bin/manua...ault&total=190
then fix ... note there is a ghetto way to bypass the detonation sensor but you could cause serious damage to your engine by doing so
Old Mar 14, 2006 | 09:54 PM
MO1's Avatar
MO1
Thanks guys..I had check the work around on angelfire before I posted. The prior owner had cut one of the wires on the connector. HAd no problems until now. It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
Old Mar 15, 2006 | 01:47 AM
japanz's Avatar
Well I would suggest you relocate the sensor. Unless you have $1500 to throw towards the dealer. How you ask...I say try searching the posts here and you will get all the answers you need..
Old Mar 15, 2006 | 06:18 AM
CanyonCarver's Avatar
Jack Of All Trades
Originally Posted by MO1
...... It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
It doesn't require engine removal. The upper and lower plenums do need to come off, which might actually be harder than removing the engine. .... that is from what I've read. If mine goes bad, it'll either get bypassed or relocated until a time that the plenum needs to come of for other things.
I've been in a Z that had the det. sensor bypassed, and the detnotation is obvious when accelerating hard. You just need to be aware of it and drive in a way that prevents it.
97gtp
May 27, 2014 07:14 PM
Aphrodite
Feb 12, 2006 06:37 PM
50thaeturbo
Feb 16, 2005 10:23 PM
jtmny1999
Aug 1, 2003 04:22 AM
ContagiouSzxt
Apr 2, 2003 08:38 PM
