detonation sensor
Hey Guys
Got detonation sensor code and correct me if I'm wrong, it's the 2 wire conector near the firewall. The wire from the harness end is busted off. Any tricks to get around it? Thx Mo:confused: |
No, replace the connector. That is the way it should be repaired.
no tricks, this isn't a magic show.
seems like a simple repair, why don't you wanna fix it? either you fix it or you don't, there's no tricks to it. |
http://www.angelfire.com/geek/vg30de...tSenRel01.html
btw: i found this in like 20 seconds wth the forum search function. |
you also might want to check and see if its the wiring or the detonation sensor.
http://www.300zx.co.uk/cgi-bin/manua...ault&total=190 http://www.300zx.co.uk/cgi-bin/manua...ault&total=190 then fix :) ... note there is a ghetto way to bypass the detonation sensor but you could cause serious damage to your engine by doing so |
Thanks guys..I had check the work around on angelfire before I posted. The prior owner had cut one of the wires on the connector. HAd no problems until now. It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
Well I would suggest you relocate the sensor. Unless you have $1500 to throw towards the dealer. How you ask...I say try searching the posts here and you will get all the answers you need..
Originally Posted by MO1
...... It's my understanding the sensor replacement and wiring requires engine removal which to me is not an easy fix. I would like to fix properly. Thanks for the suggestions
I've been in a Z that had the det. sensor bypassed, and the detnotation is obvious when accelerating hard. You just need to be aware of it and drive in a way that prevents it. |
