Detonation or turbo bearings...?
Old Mar 30, 2003 | 10:50 PM
lifegrddude's Avatar
Externally Wastegated
It could be your fuel system, anything from the pump to the injectors. If it's around 4500 and at WOT, check your injectors to make sure they are flowing and not leaking. The pump could be getting old, ZXT's also run very very lean after 4700 rpms to about 5500, or at least that's what came up on the dyno when I had my car dynoed. I also had a similar problem to yours and as stupid as this sounds, it was due to 3 things on 3 different occasions. 1. Old/bad plug wires, cap and rotor 2. Low oil 3. Bad AFM and O2 sensor. Hope this helps you out and gives you some ideas. Just another thought since you said connectors, the originals will get old and not read right, you could check on replacing them because I had to on the #4 and 5 to get my injectors to fire right.
John
97gtp
May 27, 2014 07:14 PM
MO1
Mar 15, 2006 06:18 AM
Aphrodite
Feb 12, 2006 06:37 PM
50thaeturbo
Feb 16, 2005 10:23 PM
jtmny1999
Aug 1, 2003 04:22 AM
