Dead car - need help...
Old Feb 11, 2004 | 11:34 AM
blazindonkey's Avatar
I'm new to the forum, and it looks like some good advice is offered around here, so I think I'll give it a shot.
About a week ago, I was driving and my headlights flickered a little bit. A couple minutes later, the radio just cut off. The engine ran and idled fine, but when I shut the car off, it was completely dead when I tried to start it five minutes later. The battery and alternator are both less than six months old. (Just a point of information here - by completely dead, I mean completely dead. No interior lights, no accessories - nothing. The engine doesn't even try to crank. I know it isn't not the ignition switch, since stuff that isn't wired on that switch don't work, either.) I thought it might be the main fusible link, and, after waiting a week for the part to come in, I replaced it only to find that that wasn't the problem.
Can anyone offer some advice or had any experience with everything going dead?
Please help me if you can. It sucks having to rely on others for rides everywhere.
Old Feb 11, 2004 | 12:45 PM
91zxtt's Avatar
Check your main grounding point behind the battery. You have to take the battery out to get to it. the wire from the negative battery runs directly to it. I have seen that grounding bolt corrode out completely. What your describing would happen if that main ground was interupted. Let us know what you find.
Old Feb 11, 2004 | 02:02 PM
Thanks. I'll check that as soon as I can get a ride home from work.
Old Feb 11, 2004 | 02:54 PM
emo236's Avatar
confuzed member
2nd on the main ground. Also, just b/c problems tend to happen together, you might want to check the rest of your wiring as much as you can. Your current problem is most likely dealing with your main ground, but check the rest of the grounds as well. There is also a ground on the plenum...ahh here's a link with some pictures.
Old Feb 11, 2004 | 02:55 PM
emo236's Avatar
confuzed member
this link is how to set up a ground net, this mihgt be a beneficial mod for you.
http://www.ttzd.com/tech/groundnettech.html
Old Feb 12, 2004 | 06:23 AM
yeah. that was the problem. thanks for the help.
it feels good not to need a ride.
Old Feb 12, 2004 | 09:40 AM
91zxtt's Avatar
Sweet! Always glad to help.
Old Feb 12, 2004 | 11:35 AM
emo236's Avatar
confuzed member
that's good. Are you going to try to set up the ground net? They also make kits for relatively inexpensive.
Old Feb 12, 2004 | 11:36 AM
emo236's Avatar
confuzed member
Actually, if you want, I can get you a kit for $49.95.
Old Feb 12, 2004 | 09:46 PM
Z_WRECKER's Avatar
how about $15 on ebay...
Old Feb 12, 2004 | 11:12 PM
emo236's Avatar
confuzed member
after looking into that...yea, go for that.
Old Feb 13, 2004 | 11:42 AM
91zxtt's Avatar
That one on eBAY is not necessarily designed to fit a Z32, plus there aren't instructions. Design Racing sells some of those on eBAY, and I've some bad experiences with them. There's a thread around here somewhere about building your own. I built my own. It was easy, and it fits better than any kit you'll get off eBAY. Do a search for grounding net and you'll find it. I gave pretty detailed directions on how to build it.
Old Feb 13, 2004 | 11:45 AM
emo236's Avatar
confuzed member
I posted that tech about 5 or 6 posts up. That's another route and it's realtively easy.
Old Feb 13, 2004 | 02:07 PM
Riz Z Speed's Avatar
Administrative Brown Guy
https://www.zdriver.com/forums/showt...ight=grounding
I do believe that this thread is what 91zxtt was referring to.
Old Feb 13, 2004 | 04:17 PM
emo236's Avatar
confuzed member
or maybe this post.
Old Feb 13, 2004 | 08:02 PM
Z_WRECKER's Avatar
Good stuff....thanx guys
Old Feb 13, 2004 | 08:38 PM
craZed's Avatar
thnks for the link emo ,i just had an epiphani (cant spell for shiz)
Old Feb 13, 2004 | 11:18 PM
emo236's Avatar
confuzed member
your epihany being? Are you going to make a net ground kit?
WildmaN
Sep 19, 2009 07:46 PM
njgheewala
Dec 22, 2008 07:56 PM
Fleaicous
Aug 9, 2006 09:55 AM
WildmaN
Jan 1, 2006 11:53 AM
90NA300ZX
12
Sep 16, 2005 08:01 PM
