My Z is DEAD!
My Z is DEAD!
Well as I posted in my project list, my Z is totally dead. Milky oil, 3 cylinders not firing. I am so devastated right now, I want to literally cry. Man this sucks, totally bogus to the max. So I am proceding to swap my engine out of my '81. Because it is a good strong motor, and will get me by until I get my Turbo motor done.
Well later on when I get a Turbo block and all the equipment needed. I will just run it stock with my 5 speed. I know it will be plenty fast for me. Considering my N/A's are quite quick, the way they are. Well at least one of them is.(my '81)
Check Your Head Gasket. You Might Have Forgotten To Tighten The Bolts Or Put In The Dowel Pins In All Of Your On Going Work. I Did That Once (didnt Put In The Dowel Pins) It Blew The Head Gasket 8000 Km Later. Pop In A New One And Your On Your Way. Good Luck.
Thanks but I didn't rebuild the motor. I just took the driver's side stuff off. Intake, exhaust manifold, I didn't touch the internals of the motor. Not even the valve cover. And I gurantee the motor is done until an overhaul. That is why I am swapping motors, the one in the '81 is a strong motor. So I know, it will not be a waste. But I do appreciate the thought nonetheless.
drop $350 for a new head off of ebay (guy's name is Al Allen, his heads are rebuilt and are of impecable quality) less than $200 in parts for a lower end rebuild, another $80 for gaskets, some money at the machine shop if your cylinders need to be bored, and you're done
Thanks guys for the feedback, but my motor is screwed for now. I think a piston skirt broke loose. And I believe that is why I had #4 spark plug smashed in, like a hammer hit it. Not a good thing, especially the milky oil. And the coolant leak. Plus the fact that the front 3 cylinders are firing, and the back 3 are not. And as for the swap, I know for a fact the motor out of my '81 is strong, and runs great. Also because I had the head rebuilt in 2001. And I ran him this year, and he still ran like a top. It will get me by until I rebuild a Turbo motor, and swap later on.
But I do appreciate the advice and tips.
WildmaN, Dude... I don't know what to say.
That truly sucks. I know how excited you were about getting that car back on the road. Well, try and look on the bright side. When you get the motors out of both cars, you can clean up and detail inside the engine bay really good, and you can clean up and paint the motor that's going in your car while it's out. It's only going to make it look that much better!!!! I know how determined you are too, so I'm guessing that this is a very temporary set back. I still EXPECT to see that car at MSA in April so get crackin!
Rod.
Rod.
I Got It Down To A Science. It Takes 1.5 Hours To Remove The Engine. Ive Worked On Too Many Zeds In A Hurry. I Have My 4 Zeds And A Couple Of Customers Cars To Work On. All Under The Clock, Once You Do It Enough You Find Shortcuts. If You Need To Know Just Ask It May Save You The Time.
