clutch,,,slave cylinder
Old Feb 2, 2006 | 12:57 AM
entropy31's Avatar
The Cake Is A Lie!
that was tough to read, go easy on the commas. sounds like you may need to replace your slave cylinder if thats where it's leaking from. had you noticed any change in the clutch feel before the total failure, or did it just stop working all at once?
Old Feb 2, 2006 | 06:20 AM
CanyonCarver's Avatar
Jack Of All Trades
You should refill the reservoir with fluid, jack the car up, crawl under, and while someone else is pumping the pedal, find where it's leaking from.
Old Feb 2, 2006 | 08:46 AM
emo236's Avatar
confuzed member
sounds like your clutch slave cylinder is blown. Change it and don't forget to bleed the system.
Old Feb 2, 2006 | 03:06 PM
yeah it needs to be change, the same thing happened to me in august sept i was driving when it blew stopped in this crazy busy intersection on my way to work. sucked. but replaced it all for 150 bucks didnt even have to work on it or pay for the towing.
awilkie
Feb 22, 2016 03:06 PM
mjz
Mar 1, 2012 06:41 PM
tsabboi
Jun 15, 2011 03:39 PM
BoKnows
Sep 5, 2005 09:03 PM
