Can anyone ID this connector?
Old Mar 13, 2009 | 02:27 PM
jverz's Avatar
This connector seems to be the cause of a lot of problems for me. It must be going bad but works fairly well once the car is warmed up (loose pins?) I pulled it out for the photo but it is normally tucked behind the radiator hose, hence the dry cracked boot going into the connector.
Obviously I should be replacing my wiring harness by now anyway but I figured I could put a new connector on until then.
Also, if you know what this is can you tell me how the hell it unplugs?
Oh yeah, `90 Z32 NA 2-seater
Old Mar 13, 2009 | 02:47 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
PTU connector from the looks of it. Search... the PTU and the problems it can cause have been discussed at great length on every Z32 forum.
http://www.courtesyparts.com/22020-p...-p-182593.html
Connector should just pull apart... (I don't recall it having a retaining pin at all).
Old Mar 13, 2009 | 02:52 PM
jverz's Avatar
I thought it was for the PTU, which was already replaced with the newer one. The connector doesn't want to come apart, though. I was wondering if some dealership did a hack job on the warranty.
Old Mar 13, 2009 | 04:57 PM
KasbeKZ's Avatar
Pr0n Addict
agreed. PTU for sure. i do believe mine had retaining pins (i think that's what they're called). i might prefer to call them clips. so, to get mine apart, you find the end of the metal band going around the female end of the connector, pry each end up so that it is no longer wrapping around the connector, but only touching on 3 sides. this pulls the short sides away from the plastic bump outs on the male end that stop it from coming apart. then when you put it back on, just push the clip and let it snap back to where it was.
Old Mar 13, 2009 | 05:07 PM
jverz's Avatar
thanks. i can order a new connector now. can't wait to re-pin it. *rolls eyes*
Old Mar 13, 2009 | 05:12 PM
KasbeKZ's Avatar
Pr0n Addict
order a new connector? you mean the plastic cover that holds all the little clips on the end of the wires? just clean and tighten all the little clips.
Old Mar 13, 2009 | 05:13 PM
jverz's Avatar
is it that easy?
Old Mar 13, 2009 | 05:28 PM
KasbeKZ's Avatar
Pr0n Addict
hell yeah. look at the open end of the connector once it's off. you see 6 or 7 littler connectors. each one is a rectangle with one of the long sides solid and the other long side is broken and angled in. stick an ice pick or something on the outside of each little connector to bend the broken side of the connectors inward just a little. scrape off the inside with the pick while you are in there. scrub them with a tooth brush or something too. tar-nex i believe it's called is a jewelry cleaner and is often recommended for cleaning the connectors with. scrub them with that. then dry them off and put them back together with some dialectic grease. don't forget to scrape the male connectors off too.
Old Mar 13, 2009 | 05:36 PM
jverz's Avatar
i'm concerned the wires might actually be damaged, right about where you see that crack in the boot
Old Mar 15, 2009 | 09:07 PM
napoleonzheking's Avatar
F5 Hero
if you buy it from nissan, you MUST buy a PTU to get a new harness, Z1 sells just PTU harnesses though, order one from them, replace the sub harness, and relocate the PTU.
Old Mar 17, 2009 | 09:05 AM
2nd on relocation to get it away from the heat. I have mine under the nose panel next to the intake.
Old Mar 17, 2009 | 12:52 PM
F5 Hero
thats where I have mine, I left one of the stock plastic pipes that goes to the air box (that you can eliminate after you put a pop charger on) on the driver side, punched a hole in it with a hole punch and zip tied it in there to keep it out of the elements.
97gtp
May 22, 2014 11:08 PM
FricFrac
Dec 7, 2011 09:14 AM
Sam
Mar 10, 2011 05:04 PM
KasbeKZ
17
Sep 27, 2009 06:40 AM
chicopriest
May 1, 2008 06:42 AM
