91tt fails emission test
Old Feb 10, 2005 | 07:42 PM
craftm's Avatar
91tt fails emission test. It fail at Idle " hc ppm " to high and "CO" to high.
2500 rpm is fine. I replaced Plugs,air filter,pcv val,changed oil. Car appears to run fine, I took it on a long drive before testing to make sure it was warm. I've only had the car for a few months. In Colorado Springs you need to have a emission test before you can get tags. Not sure what to check next .
Thanks Marvin
Old Feb 10, 2005 | 07:54 PM
91zxtt's Avatar
https://www.zdriver.com/forum/showth...highlight=smog
Read this.
High HC's and high CO is a sign of a rich condition; which is too much fuel. I had/have the opposite problem. What kind of plugs did you use? Could be O2 sensors or catalytic converters. What mods do you have? Has the ECU thrown and codes? Do resistance tests on your coil packs and injectors too to make sure they're all operating correctly. Try cleaning your throttle bodies as well.
Old Feb 11, 2005 | 09:04 AM
craftm's Avatar
Thanks for the help. I put NGK standard plugs in. I will need to check the other things you talked about. Thanks Again
Old Feb 11, 2005 | 08:04 PM
91zxtt's Avatar
Check your timing too. 13-17 degrees BTDC. Car should have more power at 17.
I can't remember if it says in the link I directed you too, but you could run 87 octane through it; which should improve your test results. The car won't run very well and you won't want to drive it hard until all of the 87 is burned out of the tank, but it may be worth a shot if nothing else works.
Old Feb 14, 2005 | 08:12 AM
LUKassZ's Avatar
Here in NJ we use a 100 dollar bill...
Old Feb 14, 2005 | 09:01 AM
Zgringo's Avatar
El Viejo
Sounds like people from NJ also have smart mouths. Why do you insist on posting crap when someone is trying to help another guy?
I should have said, People from NJ have a good humor. I was being a Ahole.
Old Feb 14, 2005 | 12:30 PM
Riz Z Speed's Avatar
Administrative Brown Guy
i think he was making a joke.
Old Feb 14, 2005 | 05:07 PM
Zgringo's Avatar
El Viejo
Your right Rizz...I was jumping the gun. It's not been a good week.
Sorry LUKassZ...Didn't mean to come on to you so hard. I owe you one.
Old Feb 14, 2005 | 05:24 PM
00Evan's Avatar
Banned
Awwww is Zgringo gonna cry?
Old Feb 14, 2005 | 06:09 PM
bardabe's Avatar
Bad Speller
U guy's make me laugh. lol
Old Feb 14, 2005 | 11:16 PM
Zgringo's Avatar
El Viejo
You need a woman...you keep playing with yourself you'll go blind...and be careful on your bike or you'll never reach puberity.
I'd hate to see my hero, my idol have anything happen to him.
Old Feb 15, 2005 | 06:21 AM
LUKassZ's Avatar
actually there was NO joking in my post!!! With NO egr, downpipes and testpipes, I couldn't pass emmisions if I tried. Seriously we have to find the right inspector and pay him! Usually 100 bucks covers it...
Old Feb 15, 2005 | 07:50 PM
91zxtt's Avatar
That helps.
lwilson7
Aug 22, 2007 07:10 PM
skittle
Jan 12, 2007 09:33 PM
rgus30
Nov 3, 2006 01:15 AM
Tak_Z32TT
24
Mar 8, 2006 08:39 AM
mornflt
Aug 16, 2002 10:44 AM
