oil change
Old Feb 13, 2005 | 12:13 PM
phrozen209's Avatar
oil change
im thinking about changing to mobil 1 synthetic oil on my NA Z.
how long should i wait for oil changes after i start using this oil?
should i use 10W-30 or 10W-40?
is there another oil u think i should use instead of this one?
Old Feb 13, 2005 | 01:47 PM
CanyonCarver's Avatar
Jack Of All Trades
I've been using mobil 1 since I bought the car. I use 10w40 here in SoCal. I have been changing the oil every 5k miles and it doesn't appear the least bit dirty. I've changed the oil at 5k mile intervals on every fuel injected car I've owned and the motors have all lasted well over 220k miles before I sell them.
Old Feb 13, 2005 | 01:56 PM
Zgringo's Avatar
El Viejo
Now here's someone who knows how to take care of his car..Way to go CC.
Old Feb 15, 2005 | 06:53 AM
LUKassZ's Avatar
IF YOU PREVIOUSLY USED CONVENTIONAL OIL, DO NOT SWITCH TO SYNTHETIC!!!
Unless of course you do not like your motor.
Other than that, as far as synthetic oil, Amsoil is thee best! Redline is also a very good oil.
Old Feb 15, 2005 | 05:58 PM
bardabe's Avatar
Bad Speller
why? what woudl happen from going from Regular --> Synthetic blend--> Synthetic? or just plain from Regular to synthetic?
Old Feb 15, 2005 | 06:23 PM
Jack Of All Trades
Originally Posted by bardabe
why? what woudl happen......
Higher mileage cars have been known to start burning a little bit of oil after switching to synthetics. You also might notice a little lower oil pressure. I think the benefit of the synthetics out weighs the negatives. Especially in a motor that is known to run hot and only carries 3-1/2 +/- quarts of oil.
Old Feb 15, 2005 | 07:14 PM
91zxtt's Avatar
I've been using Mobil 1 15/50 syn since I bought my car 6 years and 75k miles ago. No problems.
Old Feb 15, 2005 | 07:55 PM
LUKassZ's Avatar
well, some mechanics say switching from conventional to synthetic on a higher mileage car would ruin the seals and cause (or increase) oil leaks/consumption. Again, some say its fine to switch to synthetic.
BUT, this is the way I look at it, if half say its bad, I'm going to play it safe and not do it....
JoeGasm
Mar 8, 2008 05:01 PM
Dante
350Z Performance / Technical
18
Jan 18, 2008 07:05 PM
SportBikeMike
Apr 1, 2007 09:37 AM
speedlimits
Dec 30, 2005 11:43 PM
81 Black L28E
Mar 25, 2005 12:47 AM
