1991 Engine cuts out over certain rpm
Old Feb 6, 2009 | 11:54 AM
Hami300z's Avatar
I have a 91 300z non-turbo and for the past few months I've been having problems with the engine cutting out. It first started last summer when I filled the tank with 91 octane and I thought it was bad gas. They tested the fuel pressure and it was correct. It will start sputtering and sometimes die completely and will not start for a few minutes. After only a couple of minutes it will start again but either dies or will go at very low rpms.
Attached Thumbnails 1991 Engine cuts out over certain rpm-passview.jpg   1991 Engine cuts out over certain rpm-drivview.jpg
Old Feb 6, 2009 | 11:58 AM
Welcome to ZDriver.
84-89 300zx's = Z31
90-96 300zx's = Z32
Moved thread to Z32 section.
Old Feb 6, 2009 | 01:34 PM
rtmorgan's Avatar
Obsessive Craigslist Disorder
welcome
for future help please try to use the search feature it can be handy
now for your lil prob.
i will almost guarentee its your maf sensor plug
go through every connector and clean/ repair them.
and if you want (i do) put some dieelectric grease on them.
do this and let us know what happens
Old Feb 6, 2009 | 04:20 PM
nzniggles's Avatar
Or you may have a series one PTU which can cause problems as they warm up.
Old Feb 6, 2009 | 10:01 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Better yet, search. I recall no less than two threads about this EXACT problem... both with several suggestions and ending with the problem being resolved.
Old Feb 12, 2009 | 06:35 AM
Hami300z's Avatar
That solved the problem
Hi, thanks for the responses. I did as suggested and removed, cleaned and put back together the MAF Sensor and the problem went away. Many thanks for your help. In the future I'll make sure to search the existing threads.
Thanks,
Chris
red zee
Jan 8, 2016 09:32 AM
zlaxbro
Jul 19, 2011 05:00 PM
acastiaux2
Apr 30, 2009 11:04 AM
sanzoneb
FS: 300ZX (90-96)
Aug 25, 2006 06:39 PM
gfkeph
Jan 19, 2002 06:34 PM
