clutch pedal pressure
Old Jan 29, 2009 | 03:05 PM
twoodson's Avatar
my pedal seems to have too much pressure, i just replaced the clutch amster and slave cylinder and it started after that. do i need to bleed it or is there another problem?
Old Jan 29, 2009 | 03:38 PM
KasbeKZ's Avatar
Pr0n Addict
is it a turbo? the turbos have a booster that can go out and make it feel stiffer.
Old Jan 29, 2009 | 03:56 PM
twoodson's Avatar
NA i also had the pedal adjusted because the release point is alot farther out than it was before, but it still is farther out than i want it to be.
Old Jan 29, 2009 | 03:58 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... maybe it wasn't as heavy as it was supposed to be before. If you just replaced the components, it is likely that the old equipment wasn't performing properly and is now.
Old Jan 29, 2009 | 04:26 PM
KasbeKZ's Avatar
Pr0n Addict
indeed^^^ that makes me curious though, how far out is the release point supposed to be?
twoodson's Avatar
i just thought that the pressure had to do with the release point which is 2-3 in off the floor.
Old Jan 29, 2009 | 04:34 PM
twoodson's Avatar
^ are you serious about ATF in the power steering?
Old Jan 29, 2009 | 05:04 PM
KasbeKZ's Avatar
Pr0n Addict
yeah. lol that's what i said when i first heard. but yes, PS fluid will ruin the system after a bit of time. i speak from experience
Yes he is serious about ATF in the power steering system.
Old Jan 29, 2009 | 07:38 PM
entropy31's Avatar
The Cake Is A Lie!
exactly what i was going to say.
2nd. PS fluid will kill the pump.
Old Jan 29, 2009 | 08:58 PM
Btw, air bubbles wouldn't cause a stiff pedal, it would cause a lack of pedal pressure. And for that matter, I'd propose that you had air bubbles before and not anymore.
Old Jan 29, 2009 | 09:02 PM
yeah i cant think of ANY problem related to a clutch feeling stiffer and it be a problem with the hydraulics anyways. i say if its driving fine then done worry about it.
Old Feb 3, 2009 | 03:53 PM
twoodson's Avatar
my clutch is slipping now, I guess thats the problem.
Old Feb 3, 2009 | 03:58 PM
might have to adjust it, its possible it isnt allowing the clutch to engage fully now that you got the new strong hydraulics in there. that or its just its time to go.
Old Feb 5, 2009 | 04:04 PM
twoodson's Avatar
it seems like when the more car is warmed up, the more presure there is on the pedal. sometimes the release point is where the slutch is almost all of the way out, sometimes its 2-3 in. the clutch hasn't slipped since that day so i'm going to wait on replacing the clutch for now
Old Feb 5, 2009 | 04:44 PM
KasbeKZ's Avatar
Pr0n Addict
if it's unsteady like that (the release point), i will almost guarantee that it's hydrolic. bleed it properly (two bleed points) and see if that fixes it. if it changes it, but then it comes back, you have a leaking cylinder. you'll need to find the wet one and replace it. maybe both.
Old Feb 5, 2009 | 10:24 PM
2nd bleeding it properly. Temperature should have almost no affect on the system.
And since you said you've adjusted it before, I'm going to advise adjusting it properly:
http://specialtyz.com/clutchadj.htm
Old Feb 9, 2009 | 07:36 PM
twoodson's Avatar
thanks zl4l that seems to be thesolution for my problem. im going to try adjusting and bleeding the system tommorrow.
Old Feb 12, 2009 | 07:01 PM
twoodson's Avatar
ok i adjusted the switches the release point is fine now, but i moved my seat all the way back to get under there now the motor for the seat is burned out. i have to sit slouched just to drive it properly. the clutch still slips when its warm, im gonna bleed the system to see if that helps.
Old Feb 12, 2009 | 07:45 PM
If the clutch slips while fully engaged and it's adjusted properly, it is NOT related to the hydraulic system... your clutch is probably just bad.
Old Feb 12, 2009 | 08:23 PM
KasbeKZ's Avatar
Pr0n Addict
yeah and your flywheel is probably bad, and i've got one i'll sell you!
that was a joke. your flywheel is probably fine and i don't have one. someone understands it.
Old Feb 13, 2009 | 08:08 AM
rtmorgan's Avatar
Obsessive Craigslist Disorder
the hydraulic system is just for disengaging.
like z lover said mabe your pressure plate is worn or your dick is to thin (worn)
time for a new one!!
Old Feb 13, 2009 | 08:11 AM
rtmorgan's Avatar
ohh **** i ment to type disk
Old Feb 13, 2009 | 09:14 AM
KasbeKZ's Avatar
Pr0n Addict
zlover is going to flame me for this suggestion, but i will mention that the guy i just bought my flywheel from had a stock N/A clutch with 8k on it that he was selling for 50 or less+ shipping. though, if you aren't VERY tight on money, it is not that much more to get a brand new exedy. i just got my whole kit for $150 shipped.
Old Feb 13, 2009 | 09:22 AM
rtmorgan's Avatar
well it sounds like he needes a disk and presure plate first off and mabe a flywheel if and only if his is no good. and he wont know till its apart
