1991 2+2 no start
Old Jun 25, 2012 | 01:45 PM
buloushie's Avatar
1991 2+2 no start
Was working on the car last night, had it running while I cleaned the inside to put drivers side seat back in.I don't driver the car much not my DD so when ever I work on it I let it run.well went out today to put the seat in car wouldn't start.it cranks but doesn't turn over. So I checked the fuel pump relay by the drivers kick panel it clicks like it should. Then checked the fuse by the battery it's good, checked the cas took it out and turned it bY hand could hear each injector click so they are good. Next had a friend listen for the pump back behind the rear seat and no noise at all.
Then did the jumper wire on the FPCU. Still no start so it's the fuel pump right? Are is there anything else i need to check before I replace the fuel pump?
Old Jun 26, 2012 | 07:25 AM
Make sure the fuel pump is actually getting power (at the harness connection) before ripping into it.
bongpogi
Aug 19, 2015 11:15 AM
Rofloptacus
Apr 16, 2012 06:17 PM
moorebl
Apr 14, 2011 03:28 PM
craftm
Mar 18, 2005 02:43 AM
