Tips for starting a car that has sat for 2 years
Old May 24, 2010 | 10:44 PM
rjesus's Avatar
Was wondering if anyone had any tips for starting a 95 300ZX (non turbo) that has not been started in over 2 years. The car has aprox. 130k miles and was in perfect running condition when I parked it. I need to start it, sell it, and get it out of my driveway.
Old May 25, 2010 | 12:16 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
2 years... I'd probably drain the gas out of it, put new stuff in, oil change, remove the fuel pump relay and crank the engine for at least 30 seconds to prime the engine, then crank it until it fires. If that doesn't work, something's wrong.
Old May 25, 2010 | 02:34 PM
vitaminZ's Avatar
Oil shouldn't be an issue. Just make sure it has sufficient oil.
And give your rad a good flush (the right way), and sooner or later your gonna need a tune up, depending on the condition was before it was stored
Old May 25, 2010 | 06:20 PM
CanyonCarver's Avatar
Jack Of All Trades
Like ZLover said, crank it till you see oil pressure build on the gage. I have a fuel cut-off switch and do this even if the car has set for two weeks.
Old May 25, 2010 | 07:11 PM
This is bad advice. The contaminants that have accumulated in the oil prior to the car sitting are corrosive and will break down the oil. This is exactly why they recommend replacement every 3 months or 3000 miles, and not just every 3000 miles.
If the oil in the motor was completely fresh before sitting, it'd be fine... but I doubt this was the case.
Ultimately, you have no way of knowing if the properties of the oil have been maintained over the past two years without sending a sample to a testing facility... for $20, you know that the new oil is going to properly lubricate.
BoulderZ
May 12, 2008 02:17 PM
DGriffin
Jan 13, 2007 08:27 PM
Nforce1
Nov 29, 2005 05:10 PM
DanZ32
Oct 5, 2004 10:42 AM
icice9
Dec 8, 2003 02:22 PM
