Rust on the internal water passages of my block after machine work
Old Apr 7, 2016 | 04:22 PM
Stryker14's Avatar
I got the block back for my rebuild. They hot tanked, bored out, and also removed the casting flashing internally.
I start to put things together, I flip the block over and I see some rust come out. I poke a screwdriver in the holes and flip again and a whole crap load of rust comes out (see pictures)
I take some pictures of through the top water holes in the block and see this (see pictures)
This can't be normal, or is it?
Any help would be appreciated as I am not an expert on what it should look like!
Thanks!
Attached Thumbnails Rust on the internal water passages of my block  after machine work-img_1210.jpg   Rust on the internal water passages of my block  after machine work-img_1212.jpg   Rust on the internal water passages of my block  after machine work-img_1227.jpg   Rust on the internal water passages of my block  after machine work-img_1219.jpg   Rust on the internal water passages of my block  after machine work-img_1220.jpg
Rust on the internal water passages of my block  after machine work-img_1222.jpg   Rust on the internal water passages of my block  after machine work-img_1225.jpg
Old Apr 11, 2016 | 06:53 AM
I'm sure the hot tank dip loosened it up. When I clean out coolant passages, I pour in a bottle of LimeAway, tape up the ports, and turn the engine over a few times on the stand. Then hit the ports with high pressure water. Blow dry and hit with WD40.
Old Apr 14, 2016 | 09:29 PM
Stryker14's Avatar
thanks, I had a knowledgable friend look at it and he said basically the same thing. hit it with compressed air a bunch of times and cleaned out all the loose particles then PB Blast.
lilt304
Mar 24, 2009 06:51 PM
thetremendousti
Jun 20, 2008 09:31 AM
master300zx
Apr 10, 2006 08:50 PM
jtmny1999
Apr 22, 2003 02:32 PM
hgray14
Jun 21, 2002 09:20 AM
