Help me please!! heavily Clogged coolant passages :-\
Old Jun 19, 2008 | 02:46 PM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
Okay on my L28et which has been reduced to just the block and head , I have found that there is alot of this copper/brown colored build up anywhere that the coolant is. I stuck a vacuum to the water outlet and rusty colored water came out. There are hard build ups all throughout the engine and I have picked most of them through with a screwdriver, but I don't know what to do!! If I put the head back on with the gasket, and then I put a high pressure garden hose to the water inlet, will it flush it good enough? HELP! I have no idea what to do...
Old Jun 19, 2008 | 03:02 PM
280zx2by2's Avatar
Haterade by da gallon!
most old cars seem to look like this... its rust not copper i think it means that at some point the car didnt have a good enough coolant to water ratio
no problem unless the passages are comletely blocked, if your still worried i guess you could sandblast the holes out???? im sure some other peps here know more than i do, actually its a fact
Old Jun 19, 2008 | 08:18 PM
When in doubt, you could use google. Looky what I found:
http://www.mustangforums.com/archive...2695304-1.html
http://www.corrosionvci.com/rust-rem...plications.htm
The EASIEST way (but definitely not the cheapest) is to get the block dipped at a machine shop. If you are rebuilding a motor, you should have it checked at a machine shop anyway.
Old Jun 20, 2008 | 09:31 AM
I'm not rebuilding it because, honestly, I'm too afraid to take it all apart because even though I have a FSM I don't think I would be able to put it all back together right and I'd end up blowing up my new engine haha. I am however replacing all the gaskets that I can on it.
rsperegrin1
Nov 21, 2013 06:59 AM
jofwolves
Nov 14, 2011 11:24 AM
HaulinZ
Nov 9, 2008 12:24 PM
fuego305
Nov 6, 2004 11:13 AM
