Problem 300z lost power
Old Feb 7, 2012 | 08:56 PM
roby300z's Avatar
hi im new here and ineed of some help.
A few months ago my Ac belt came of , I drive without because people told me it was fine.3 days later my car felt like my clutch was slipping. I put on new wheels , changed the belt , I was messing with the air filter and fuel filter and my car got better. Only now it was very slow hard to accelrate and grinding noise came from the back.I change my bearings and nothing happened I changed my differential and it took the noise away and my car is running okay now.But after all that it still feels like it lost power , I cant accelerate as fast as i want to and seems to have a hard time doin so. PLease help , should I take it the the shop?
thank you for your time
Old Feb 8, 2012 | 12:27 PM
roby300z's Avatar
Anyone ?
Old Feb 8, 2012 | 05:19 PM
Welcome to ZDriver!
Your post isn't too clear, and that's probably why no one has responded to you.
I read your post several times... so you just started replacing stuff until the sound changed? Have you pulled the ecu codes? Did you verify that the new diff has the same gear ratio as the stock one?
Old Feb 8, 2012 | 06:01 PM
3riCJbOi's Avatar
one sound fits all
Is the car misfiring at all?
did you do a compression test?
A car needs three things to run
spark, fuel, compression
if your engine has an issue with any one of these you will experience power issues if worse a no start
Old Feb 8, 2012 | 08:11 PM
roby300z's Avatar
Welcome to ZDriver!
Haha sorry bout that , I havent pulled the ecu codes yet ill do it 2m and how do i check gear ratios?
sorry bout this im new to cars aswell.
No misfires n havent done a comp test.
the thing is the car has power but its not pulling
Old Feb 8, 2012 | 09:57 PM
The twin turbo had an r230 rear diff the n.a. had an r200. If you put a TT diff into your non turbo it'll feel slower.
Old Feb 10, 2012 | 10:46 AM
roby300z's Avatar
The diff I put in was from a non turbo 90' to my 94 non turbo
How much difference would a bad air filter and fuel filter be?
Old Feb 10, 2012 | 06:17 PM
3riCJbOi's Avatar
one sound fits all
It can be pretty bad
the stock airbox has a lot of restriction already plus a dirty clogged air filter will really limit the amount of air entering the intake and oxygen is everything.
Soo a dirty air and fuel filter will make a difference but not a major difference
it will drive smoother and cleaner to have those replace
Old Feb 10, 2012 | 09:58 PM
roby300z's Avatar
Thanks !
I finally found the problem my rear right wheel moves forward back n forth about 1" when jacked up. I think it's an Axle
Old Feb 11, 2012 | 01:30 AM
Ball joint is my guess, doubt it would make the car feel slow.
burble_boy
May 1, 2013 09:28 AM
Shane Eichacker
Nov 16, 2012 06:52 PM
GTH
May 13, 2011 03:31 AM
Lycan_leader
24
Jul 1, 2005 04:09 PM
DONR
Feb 26, 2002 06:13 PM
