Misfiring?
Old May 17, 2010 | 10:14 PM
3riCJbOi's Avatar
one sound fits all
Misfiring?
Hey guys, my Z is acting up
Theres like misfiring going on and it feels like theres a big lack in power.The sparks plug are pretty new, only about 2 years old. The odd thing about it is that the car seems to misfire at certain times. sometimes it runs just fine and a minute later it running super slow and laggy. Whats the deal with that ?
Weird just thought ill ask you guys to see what you think
any help would be great.
Old May 17, 2010 | 10:49 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Test your injectors - pull connectors off, read resistance across the leads. Should be 10-14 ohms.
Come back with results and we'll move on from there.
Old May 18, 2010 | 08:10 AM
3riCJbOi's Avatar
one sound fits all
Pulled and tested all connectors all read about 14 . It just so odd that every now and then there's no misfire run fine like today. Drove it out on the morning it fine but now it misfiring again.
Old May 19, 2010 | 11:17 PM
3riCJbOi's Avatar
one sound fits all
Found the issue, some of the connectors for the fuel injectors were bad. Had to replace 3 of them. The other three were good but a lot of corrosion, had those cleaned real good. Reattached the connectors and tested them reads at around 14 and now the car runs good as new. Actually a little better then before too.
Old May 19, 2010 | 11:25 PM
Usually, misfiring is a result of bad injectors or bad injector/coil pack connectors. (For future reference.)
Glad you figured it out.
Old Nov 9, 2010 | 04:22 PM
3riCJbOi's Avatar
one sound fits all
Misfire
Hey guys, my Z been having misfires recently. It's comes and goes, I checked all the fuel injectors they work fine and connectors are new recently replaced. But I still get a little misfire once in a while. Any ideas on what I should do?
Old Nov 9, 2010 | 04:24 PM
Merged with your previous Misfire thread....
Old Nov 9, 2010 | 04:43 PM
3riCJbOi's Avatar
one sound fits all
All injectors tested and fuel injector connectors REPLACED. Still has misfiring, it was fine since the last time. I cleaned the sub harness for the PTU. I'm not sure what to do next.
3riCJbOi
Apr 30, 2011 10:35 PM
BlueKitsune
Jul 31, 2010 09:02 PM
elrivas
May 24, 2006 01:30 PM
tortle2
Aug 28, 2005 03:27 PM
smoke show
Jul 25, 2003 04:12 PM
