Misfire, please help troubleshoot
Old Apr 29, 2012 | 04:27 PM
blckdrgn's Avatar
Misfire please help troubleshoot
Hey all,
I have a 92 300zx TT that is misfiring and I think the issue has to do with cylinders 5 and 6. For those that dont know... this is the cylinder numbering (according to alldata)
(view from above, rear of engine)
56
34
12
Heres a bit of the background story -
#1 March 2011 blew the passenger side turbo
#2 Sept 2011 replaced both stock T22 turbos with 2 T25 turbos
#3 This is where the misfire started, it felt like it was about 80% as fast as before the turbo blew, and over the next couple of days degraded to more like 50-60%. It was especially slower in the low end.
I had a diagnostic done at this point and was told cylinder 6 was reporting as a dead hole so I have since replaced all 6 spark plugs (it has a z1 ecu upgrade and 555cc injectors so I got the spark plugs they recommend after that upgrade) and the #6 coil pack.
While the car is idling, I can unplug the coil pack connector on cylinder 1, 2, 3, and 4 and the RPM's drop a bit and come back up when I reconnect it. Cylinders 5 and 6 though cause no change in the RPM's when disconnected/reconnected.
The engine had to be pulled when the turbos were replaced so I'm not sure if maybe something was not hooked back up right or not. There are 2 wires that are not connected to anything (from the wiring harness). Here are a couple pictures of them attached, if someone could help me identify what they are and where they should go I would greatly appreciate it.
I have replaced all plastic 6 coil pack connector also tried disconnecting the coil pack wire from cylinder 3 and connecting it to cylinder 5, the RPM's drop but do not come up when it is plugged into #5. The RPM's also do not come up when coil pack connector 5 is connected to cylinder 3. This may be normal behavior, I dont know enough about cars to tell though.
I also tried taking the coil pack from cylinder 3 and putting it into cylinder 5, same results.
I have done multiple compression tests and all cylinders are in the correct range.
I really want to get my car going again, I havent been able to drive it for about a year because of the turbos and the misfire melting the new cats I put on it.
Thanks in advance for any advice!
PS> Pictures 1 and 3 are of the 1 disconnected wire on the driver side, picture 2 is the disconnected wire on the passenger side
Attached Thumbnails Misfire, please help troubleshoot-photo-1.jpg   Misfire, please help troubleshoot-photo-2.jpg   Misfire, please help troubleshoot-photo-3.jpg
Old Apr 29, 2012 | 08:39 PM
Cap's Avatar
Cap
Give me some Numbers.. I'd like to know what the Compression Actually is..
All Plugs out.. throttle Wide Open.. Spin till max Number.. All Cylinders..
Do you have a Wideband Mixture Gauge.. Can you get one?.
With the Car running, ( Idling ) Use a Spray brake Cleaner with a 'Snout', and Squirt around the Injectors of Cylinder 5/6.. and at the Intake Plenum Seam .. looking for leaks.. if it's leaking, the RPM will jump up..
Cap
Old Apr 30, 2012 | 09:56 PM
blckdrgn's Avatar
Cap
Hey Cap, thank you for the response and suggestions.
I didnt record the exact numbers but they were between 140-150 psi on each.
I dont have a wideband mixture gauge, I wont be able to get one for a couple weeks. I'm assuming it would be running lean since 2 cylinders arent firing..
I will do another compression check and record each cylinder. I will also try what you suggested with the brake cleaner and post the results.
tecnica
Sep 18, 2013 12:36 PM
kazoku
May 27, 2011 10:14 PM
scott123
Aug 8, 2010 05:09 PM
ZOMBIEEATER
27
Aug 20, 2006 05:19 PM
dpotter
Jan 16, 2005 10:06 AM
