I think im in a pickle- wheels spin w/clutch down, and hard to shift into gear
Old Feb 9, 2014 | 09:22 PM
Carson B's Avatar
So a week ago, I replaced my clutch(bearings, disc, and pressure plate), only to notice after I started my car it was a bad throw out bearing (made a awful noise and even smoked). But seeing as how the old one seemed perfect, I greased it up and swapped it out, and it seems great. Then there is this. Now it is hard to shift through my gears (barley can get into fourth, fifth and reverse without SERIOUS strength) and while my car is just in neutral or while on clutch my rear wheels spin(I can stop them with my hand, then they continue spinning). I completely bleed the clutch, got a new slave, and adjusted the pedal. What could be my problem? How to fix?
tl;dr Replaced clutch, now wheels spin while on clutch pedal & VERY hard to switch gears. Thanks!
Old Jun 1, 2014 | 05:25 PM
Anthonylvega's Avatar
So I'm not to sure about the wheel spinning problem but as to the tuff shifting I had the same problem. Unfortunately it broke my shift support bracket but we fixed that with no problem. Anyway when you put the bolt that connects the shifter to the selector(in my case it is a gold rod leading into the gear box) but whatever color it may be that bolt connecting the shifter to the gold rod is most likely over tightened. I went back in and loosened it a bit and now the car shifts better then when I got it
bongpogi
Mar 30, 2015 11:38 AM
Newbie1792
Mar 17, 2013 05:02 PM
tyler2800
Feb 26, 2013 02:54 PM
KENZ
Aug 18, 2005 11:13 PM
bahollings
Jun 29, 2003 04:48 PM
