Help. Im new to Twin turbos. blue smoke
Old Jul 16, 2008 | 01:47 PM
myfairlady's Avatar
Ok my friends mechanic says its not the head gasket but the turbo oil preasure lines that is causing the blue smoke. IS this true? Blue smoke is coming out of my exhaust. I need help. Please please please please please!!!
Old Jul 16, 2008 | 02:42 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
It cannot be a turbo oil line that is causing burning oil in the exhaust (the oil lines feed the center section, which is supposed to be sealed off from the turbine). One of the turbos is shot. (The center section is leaking oil into the turbine, where it is burning off and exiting through the exhaust.)
Old Jul 16, 2008 | 05:18 PM
myfairlady's Avatar
wow so i have to replace one of them... Well hopefully i can fix it. I know there is not alot ofroom to do that
Old Jul 16, 2008 | 05:46 PM
CanyonCarver's Avatar
Jack Of All Trades
A compression test will determine if it's a head gasket or a turbo. Besides the blue smoke, if it seems to run fine, it's probably a turbo.
Old Jul 16, 2008 | 07:36 PM
Easiest way to replace turbos is to remove the engine. And 2nd what CanyonCarver said... do a compression test to make sure it's a turbo and not the head gasket (though I fully believe it to be a turbo).
Old Jul 16, 2008 | 08:23 PM
myfairlady's Avatar
Yeah your right. Wow. DO i have to drop the engien to replace the turbos? That kinda sucks if I had to.
Old Jul 16, 2008 | 09:04 PM
The turbos can be replaced with the engine in the car, but I am ABSOLUTELY SERIOUS that it is easier to just remove the engine.
http://www.ttzd.com/tech/turbotech.html
Step 1: Remove the engine
http://www.ttzd.com/tech/enginetech.html
If there were an easier way, the writeup would've detailed how to do it.
My advice though, do not remove the alternator or power steering pump from the engine. Leave those connected and pull the engine with them on the motor (just disconnect them). The AC compressor should be removed and left in the chassis though (without disconnecting the lines), so you don't lose your AC charge.
dave90300zxTT
13
Jun 10, 2015 02:16 PM
TRBruno
Jan 13, 2012 03:22 PM
Prokopas
Mar 4, 2011 01:03 PM
SHADY280
Jan 19, 2009 07:12 PM
myfairlady
Jul 16, 2008 01:48 PM
