Blue Smoke WOT
Old Jan 12, 2012 | 10:26 PM
TRBruno's Avatar
Blue Smoke WOT
Hello i made a post about buying a new tt but noone seemed to reply. ill keep it short. car is 1990 5 spd TT no engine knock no sputter no overheating only 65000 km. Car blows blue smoke out exhaust under boost. I dont think its valves or head gasket cause its only under boost and only blue smoke. Turbo seals ? Car still boost at 7 psi
Old Jan 12, 2012 | 10:59 PM
Could be rings.
Old Jan 12, 2012 | 11:01 PM
TRBruno's Avatar
Could be rings.
Not that either comp good. if its turbos would adding thicker oil be a very temporary fix till i get new turbos? What can i do to reduce smoke till i get turbos? Thanks for your time also
Old Jan 13, 2012 | 12:36 AM
I'd put money on turbo's or head gasket.
And no, thicker oil won't fix the leak unless you go with a crazy thick (gear oil) weight, even then it will just lessen the leak.
Old Jan 13, 2012 | 02:56 AM
BOOSTINMYZ's Avatar
20w 50 oil is alright,won`t fix leak. turbo oil seal?
Old Jan 13, 2012 | 10:03 AM
TRBruno's Avatar
Okay thanks for the help guys. Is the turbo kit off ebay for 650any good? Says its two t2/t25. One mire thing is it risky to drive the car if turbos goin bad? Im not gonna drive it hard
Old Jan 13, 2012 | 12:50 PM
Bates's Avatar
I wouldn't risk it.
Old Jan 13, 2012 | 02:20 PM
TRBruno's Avatar
Could you explain why? Because of the turbo possibly coming apart?
Old Jan 13, 2012 | 03:14 PM
Rupe's Avatar
Horsepower Mathematician
I think what he meant was don't buy turbos off ebay. Not sure if turbos going bad would be an issue, as long as they don't seize mid-drive I'd imagine you'd be OK.
Old Jan 13, 2012 | 03:22 PM
TRBruno's Avatar
Oh alright sorry for confusion. but thank you Rupe!
dave90300zxTT
13
Jun 10, 2015 02:16 PM
Prokopas
Mar 4, 2011 01:03 PM
SHADY280
Jan 19, 2009 07:12 PM
myfairlady
Jul 16, 2008 09:04 PM
myfairlady
Jul 16, 2008 01:48 PM
