Harmonic balancer
Old Aug 5, 2013 | 11:23 AM
Artyzb29's Avatar
Harmonic balancer
I have a 2+2 automatic 1990 300zx non turbo, I'm having trouble getting the bolt out. If anyone can help me out I would appreciate it.
Old Aug 5, 2013 | 11:46 AM
Welcome to ZDriver!
The crank pulley (harmonic balancer) bolt is torqued on at ~150ft/lbs. Usually you need a beefy 1/2" breaker bar and impact socket to get it loose, or you can brace the breaker bar against the frame rail and crank the engine super quick. Just make sure you've placed the breaker on the correct side so it will loosen the bolt. And disconnect the coil packs.
Old Aug 5, 2013 | 11:55 AM
Artyzb29's Avatar
Do I need to remove all the belts for this or can I just do it with the belts on.
Old Aug 5, 2013 | 05:04 PM
Rupe's Avatar
Horsepower Mathematician
Wouldn't it be easier to just disconnect the fuel pump relay?
Old Aug 5, 2013 | 07:14 PM
Easier, yes... safer, no. A general rule of thumb when you don't want the engine to start, is disconnect the spark. If you disconnect the fuel pump relay, there is still ~35psi fuel to burn for a few seconds. That's enough time to wrap a breaker bar through your engine bay.
Old Aug 5, 2013 | 08:47 PM
Rupe's Avatar
Good point!
RSuave08
Apr 17, 2014 08:46 AM
iamericgee
Jul 9, 2012 06:00 PM
84z31nonturbo
Feb 28, 2008 07:32 PM
ChasZ
Jan 19, 2004 08:03 AM
lance75_280z
Jun 23, 2003 10:11 AM
