Electrical issues
Old Aug 8, 2013 | 06:50 PM
worder's Avatar
Electrical issues
Alright so I'm here in Canada and we need to have daylight running lights on our cars, now since mine was american i had to install a DRL. I ended up installing the module on the fog lights, i think that's what they're called.
Anyway ever since then I'm getting the handbrake warning light and the burnt out brake light warning light on my dash for no reason. There is also my radio, while aftermarket, was working fine up until recently.
Basically I'm all out of ideas as to what could be the issue here.
Old Aug 8, 2013 | 10:15 PM
Have you tried disconnecting whatever you did for the DRL to see if the problem goes away?
Old Aug 10, 2013 | 06:35 PM
worder's Avatar
Ooops, had a bit of a brain fart when I installed the DRL module, had plugged it into the ECU fuse in the engine bay, was giving weird feedback to the ECU.
Thanks
Dann Dunn
Aug 25, 2013 05:22 PM
Zcart
Mar 8, 2013 05:03 PM
87300ZZzz
Jan 23, 2013 06:55 PM
livinzlife
Jul 15, 2007 09:25 AM
