Engine Knocking
Old 09-27-2010, 02:31 PM
islandtuner242's Avatar
Engine Knocking
ok got the car home found out the guy disconnected his fuel pump and never hooked it back up got it running and found out that everything electrical and mechanical was working.....i started the engine and realised that the engine was knocking....i'm not sure what it is as of yet i was wondering if anyone has any idea of what it might be
islandtuner242 is offline
Old 09-27-2010, 02:41 PM
Tough Guy
domsgarage's Avatar
Could be a lot of things. Bad fuel, off timing, rods.
I think a messed up flywheel could cause a knock too.
Is it a KNOCK or is it like a tapping sound?
Ive heard of a slight valve tap being pretty common with these motors.
domsgarage is offline
Tough Guy
domsgarage's Avatar
run the codes too.
Old 09-27-2010, 02:49 PM
it's a knock that increases along with the throttle....as i press the throttle the knocking get faster
Old 09-27-2010, 02:53 PM
Tough Guy
domsgarage's Avatar
run the codes, could have an issue with your knock sensor.
Old 09-27-2010, 03:25 PM
just finish running the codes and this is what i got:
13* engine coolant temp. sensor circuit
Old 09-27-2010, 03:30 PM
but that still doesn't explain the knock
Old 09-27-2010, 03:41 PM
Change the oil and use thicker oil, if it still continues narrow down the area where the knock is.
hoov100 is offline
Old 09-27-2010, 03:49 PM
the sound seems to be coming from the passenger side further back closest to the battery
Old 09-27-2010, 04:15 PM
Encyclopedic Knowledge
ZLover4Life's Avatar
High or low pitched? A lot of people (read: idiots) describe ticking as knocking. Ticking is valves, knocking probably means you have bad crank bearings. The former requires an oil change and a nice long WOT highway run to build up oil pressure to force the air out; the latter requires a rebuild.
ZLover4Life is offline
Old 09-28-2010, 01:59 PM
it's definitely a knock... i've looked up some videos and their "ticking" sounds nothing like my knock
Old 09-28-2010, 03:53 PM
Time to buy a set of bearings, a FSM, rent an engine hoist, and free up a weekend.
Old 09-28-2010, 05:11 PM
If you plan on replacing the engine and not rebuilding it, you can use some thinner gear oil in the motor to quite it down. Only do it, if you are replacing the motor all together though, as gear oil is nasty.
hoov100 is offline
Old 09-30-2010, 08:47 PM
well changed the oil and the sound seemed to lessen like it was slowly getting better.....but wth imma just get a new motor and call it that
forcedfedz32
25
05-02-2009 10:01 AM
TecherZ
12-14-2006 11:20 AM
Dave Hamby
10-27-2006 06:35 PM
dhizzy
12-15-2002 10:13 AM
ScottieGNZ
06-25-2001 10:04 AM
Quick Reply: Engine Knocking
