ECU Questions
ECU Questions
So i got a 1994 300 n/a and i need a new ecu for it. Im used to the s130 so i dont have much knowledge on this one.What all year 300s can i take the ecu out of to replace mine?Any help would be great.
________
Glass Water Pipes
________
Glass Water Pipes
You should be able to use any NA computer from 90-95 if you have a 5-speed. If you have an auto then you need the computer for an auto. You can use an ECU from an auto car on a 5-speed you will just get a trouble code for the transmission. In 96 they went to OBDII so those ECUs are different.
Here's a link to verify the ECU numbers.
http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
That's true if you use a Cali ECU it will be expecting an EGR temp signal and will give you a code 35 without it. Will this cause any problems? If you use an auto ECU in a 5-speed you get a trouble code there also but doesn't appear to cause any problems. I think they added the EGR temp sensor to both Fed & Cal cars in 94-95 so for Twitch it might not make a difference either way.
Twitch I may have an extra ECU that I might part with. It's Fed and for an auto. I'll check when I get home.
Easiest way it so look into where the car was first sold (CarFax). lol If it was sold at a dealership in Cali, it's a Cali emissions car. Otherwise, you can check for the EGR temp sensor.
One of the digits in the VIN can also tell, but as TwinTurbo.NET's bookmarks are down, I can't get to the writeup that has that information.
