ECU Questions
Old May 12, 2010 | 02:02 PM
Twitch's Avatar
ECU Questions
So i got a 1994 300 n/a and i need a new ecu for it. Im used to the s130 so i dont have much knowledge on this one.What all year 300s can i take the ecu out of to replace mine?Any help would be great.
________
Glass Water Pipes
Old May 12, 2010 | 05:30 PM
xpwarrior's Avatar
You should be able to use any NA computer from 90-95 if you have a 5-speed. If you have an auto then you need the computer for an auto. You can use an ECU from an auto car on a 5-speed you will just get a trouble code for the transmission. In 96 they went to OBDII so those ECUs are different.
Here's a link to verify the ECU numbers.
http://www.jimwolftechnology.com/wolfpdf/ECU-ID.PDF
Old May 12, 2010 | 07:32 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
You also need to differentiate between Cali and Fed emissions.
Old May 13, 2010 | 06:48 AM
xpwarrior's Avatar
That's true if you use a Cali ECU it will be expecting an EGR temp signal and will give you a code 35 without it. Will this cause any problems? If you use an auto ECU in a 5-speed you get a trouble code there also but doesn't appear to cause any problems. I think they added the EGR temp sensor to both Fed & Cal cars in 94-95 so for Twitch it might not make a difference either way.
Twitch I may have an extra ECU that I might part with. It's Fed and for an auto. I'll check when I get home.
Old May 13, 2010 | 01:52 PM
nismo619's Avatar
so what your saying is if you have a 1993 300zx auto and wanting to upgrade the ecu to say a 1990 or 1991 chiped ecu it will work just fine ? right ? how do you know if the car is fed or cali ?
Old May 13, 2010 | 05:05 PM
Yes, especially in this case. Upgraded ECUs for all 90-95 Z32's (assuming same specifications, such as transmission, motor, injectors, intake) are identical. The only difference between upgraded ECUs between model years are injector changes, really.
Easiest way it so look into where the car was first sold (CarFax). lol If it was sold at a dealership in Cali, it's a Cali emissions car. Otherwise, you can check for the EGR temp sensor.
One of the digits in the VIN can also tell, but as TwinTurbo.NET's bookmarks are down, I can't get to the writeup that has that information.
Old May 14, 2010 | 06:01 PM
Twitch's Avatar
Thanks everyone. Xp warrior that would be great just let me know
________
Drug test
Old May 22, 2010 | 08:31 PM
nismo619's Avatar
can you use a manual ecu in a automatic ? this is the final question. :-) a 1991 ecu 8bit can be used in a 1993 300zx made for the 16 bit ?
Old May 22, 2010 | 10:16 PM
Absolutely not.
Old May 23, 2010 | 05:44 AM
CanyonCarver's Avatar
Jack Of All Trades
I'm running an older 8-bit ecu with an Ashspec fed. chip in my '93 Cali car.
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
SandW
Oct 11, 2006 08:08 AM
pearly whites
Aug 18, 2004 06:20 PM
