Blower Motor Won't Shut Off
Old Nov 3, 2013 | 04:53 PM
dtc69's Avatar
Anyone know what would cause the climate control fan blower motor to not shut off when I move the switch to off? The fan will respond through settings 1-4 (speeds up as it should), but will not shut off. I tried another control module (dash pod) and the same thing happens.
It is a 1990 300zx auto.
Thanks
Old Nov 3, 2013 | 08:42 PM
Pull / check the relay.
Old Nov 8, 2013 | 04:19 AM
dtc69's Avatar
Well I found both relays (behind the fuse box and behind the glove box) and replaced them with some other old ones I had. Nothing changed - the darn thing still won't shut off. So unless those were bad also I am stumped....
Old Nov 8, 2013 | 09:10 AM
Then it's the climate control switch.
Old Nov 8, 2013 | 06:02 PM
dtc69's Avatar
Is that the dash pod switch to the right of the steering wheel? I already tried that if so. Let me caveat that with it was from a junk yard so I am not sure of how good it is. What are the chances it could be bad also?
Thanks for you help!
davidjoe007
Jun 29, 2021 04:45 PM
davidjoe007
Apr 16, 2007 08:40 PM
y2ktranny
May 28, 2004 10:26 AM
ZorroZ
May 14, 2003 10:11 AM
del
Jan 7, 2002 05:59 PM
