Battery Randomly Drains
Old Jan 3, 2011 | 12:27 AM
islandtuner242's Avatar
ok i've been having this frustrating situation for a while now... i connect the battery cables to the terminals and with in a few days my battery is completely dead (no lights on the dash turn on as if the battery isn't there at all)............ any ideas anyone
BTW here is a short clip showing how the cables are currently connected
http://www.youtube.com/watch?v=coizhdnUpIk
Old Jan 4, 2011 | 10:01 AM
z32convertible's Avatar
I am having the same issue. No lights are on at all. The only thing I can think is maybe the aftermarket stereo is draining mine. But, I don't even have the face plate on the stereo. So, I too am looking for others who may know.
Old Jan 16, 2011 | 12:07 AM
sqwatdog's Avatar
Passive restraint system fuse
I had a random power drain on my Z and it turned out to be the Passive restraint system (seat belt). It releases the tension on the seatbelt or something when the door is open. I pulled the fuse for it from the fusebox under drivers kickpanel and the power drain went away. I never had the issue fixed and the Z died from other causes before I could look into it more.
Old Jan 16, 2011 | 09:42 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
What year is your car? (The specifications of your car [NA/TT and year] should be included in almost every thread in which you're asking for technical help.)
Do you have an aftermarket alarm with active sensors (impact, motion, etc)?
Do you have an amplifier that is wired directly to the battery without a control wire going to a switched power source (like the stereo's control wire, or some other ignition-activated power source)?
How old is your battery?
Old Jan 30, 2011 | 02:54 PM
sorry i took so long to respond been working crazy hours... it's a 1990 N/A factory EVERYTHING no sound system, and that battery was just bought 2 days before
Old Jan 30, 2011 | 04:26 PM
rogerz's Avatar
Grumpy & Helpful
pull the ground strap. hook an ammeter between the battery post and terminal. see if you see a drain. if so start pulling fuses to see if it goes away. if no drain then charging system suspect. take it to a battery shop for analysis usually free.
Old Jan 30, 2011 | 07:25 PM
nismo619's Avatar
I had a problem with my " alarm " yellow light always staying on draining my car battery on mh 1993 300zx n/a auto. 2+2 it still acts up sometimes.
Old Jan 30, 2011 | 07:59 PM
i recently took out my factory alarm cause my dad said he saw my headlights on one morning so i think that could be the problem for now
SlicktopS130
Jun 27, 2021 04:35 PM
Turbo Biscuit
Mar 26, 2012 08:24 PM
CraigS
Aug 14, 2006 01:27 PM
Noor
Jul 21, 2003 01:26 PM
ex247
Nov 25, 2002 02:37 PM
