shake while engaging clutch
Old Feb 25, 2018 | 05:12 PM
mjselling's Avatar
1991 z32 5 speed na coupe, my issue is a fairly violent shake when at stop and engaging clutch, when clutch is fully engaged shaking stops. One would think it would be a clutch issue but everything from the pilot bearing to the differential which I changed the fluid, new clutch master and slave cylinders, new stainless steel hose, flywheel, pressure plate, clutch disc, one piece driveshaft, transmission mounts differential mounts too, don't feel it in the shifter and seems to be coming from the back of the car.only happens when if first gear, Any thoughts or ideas would be appreciated, Thanks
Old Feb 26, 2018 | 03:34 PM
Cobalt60's Avatar
The mounts would make sense. Did you also look at the engine mounts?
Wonder if someone could see movement in the drive train when it happens.
Old Feb 27, 2018 | 07:09 AM
mjselling's Avatar
Old Feb 27, 2018 | 07:11 AM
mjselling's Avatar
motor mounts are o.k., I forgot to mention that it doesn't do it all the time, seems like after I drive for a while is when it happens. Doesn't do it when I first start.
Old Mar 1, 2018 | 06:33 PM
Cobalt60's Avatar
Seems like the clutch would be a good place to look since all the mounts are good. Wonder if one/more springs are broken. Maybe something didn't go back together quite right.
Old Aug 19, 2018 | 12:02 PM
mjselling's Avatar
found that the light weight flywheel is the culprit, changed to an oem 20.2 lb flywheel, shake is gone and a pleasure to drive agan
SlicktopS130
Sep 16, 2014 05:26 PM
professor229
Mar 19, 2014 09:38 AM
RETICON
Sep 15, 2012 04:10 PM
300zx nw
Apr 21, 2005 12:20 AM
-GrimmZX-
Apr 26, 2004 05:28 PM
