shake while engaging clutch
1991 z32 5 speed na coupe, my issue is a fairly violent shake when at stop and engaging clutch, when clutch is fully engaged shaking stops. One would think it would be a clutch issue but everything from the pilot bearing to the differential which I changed the fluid, new clutch master and slave cylinders, new stainless steel hose, flywheel, pressure plate, clutch disc, one piece driveshaft, transmission mounts differential mounts too, don't feel it in the shifter and seems to be coming from the back of the car.only happens when if first gear, Any thoughts or ideas would be appreciated, Thanks
