Knocking sound when brakes applied
Old Aug 16, 2006 | 11:37 AM
Dave Hamby's Avatar
93 Non-Turbo 2+2
Just installed slotted Rotors with Hawk Pads... they work great except for when applying the brakes hard. Sounds like a knocking sound from the right front. I pulled the wheel, pads, caliper and all looked good. Any ideas?
Old Aug 16, 2006 | 12:22 PM
CanyonCarver's Avatar
Jack Of All Trades
What brand of rotors?
Old Aug 16, 2006 | 02:18 PM
Dave Hamby's Avatar
Power slot
Old Aug 16, 2006 | 02:23 PM
silvrhand's Avatar
Snazzy Title
that's the ABS actuator kicking in more than likely. Are you really standing on the brakes like in an emergency stop?
Old Aug 16, 2006 | 04:15 PM
Dave Hamby's Avatar
yes it does it when I really crank down on the pedal. I am usually very kind to my breaks, but in this situation I was instructed to seat the pads by making a series of slow stops then hitting 50mph and braking hard. The sound it made was similar to the ABS system kicking in, but I thought it was a bit loud.
When I changed the brake pads I had to bleed a bit of fluid out in order to get the pistons to open enough to get the pads in. I only had to do it on the right front, and that was coeincidently the same side the noise is coming from. Would the actuator make unusually more noise if the brakes were lean on fluid? or got a bit of air in the line? (I am fairly sure no air got into the line).
Old Aug 16, 2006 | 05:57 PM
silvrhand's Avatar
Snazzy Title
It's probably just the ABS kicking in, it's really loud in the Z. You'll know if you had air in the line as the brake pedal would have gone soft on you after 2/3 stops. The Hawk pads are very nice, also slotted rotors tend to make more of a whirring sound when applying heavy braking as well.
megaZ
Apr 17, 2015 07:26 PM
jdina8890
Jul 2, 2014 09:09 AM
forcedfedz32
25
May 2, 2009 10:01 AM
86z31drifter
17
Jan 6, 2007 07:00 PM
hadudj
Oct 17, 2002 06:17 AM
