Lamp Warning Lights When Brake Applied
Old Jul 1, 2003 | 11:26 PM
maxp's Avatar
i got the same problem, even after i changed the bulbs, the lamp usually comes on when i am stuck in traffic and have to apply the brake continiously, it may be a defect bulb check relay which sits on the internal fuse block (?)
Anybody else?
Old Jul 2, 2003 | 08:57 AM
tsefreeflow's Avatar
I'm Chillin
You might want to check the bulb contacts on bulb and plug and clean any corrosion off of them. Mine did the same and all I did was clean the connections and its all good now.
Old Jul 17, 2006 | 02:30 PM
Zwanter's Avatar
Hi, I just saw this post and i have a similar problem. My brake lights don't work at all, only the third brake light works. My car came with the J-Spec or JDM tails already installed.
From searching I have found that the brake light sensor in the back hatch may be the culprit but when I went to the Nissan Parts counter they couldn't tell me the part numebr. I was wondering if anyone might know the part number? Thanks a lot. Almost forgot, its a 1990 Twin Turbo.
megaZ
Apr 17, 2015 07:26 PM
henrycas
Oct 25, 2011 01:50 PM
Bam1234567
Apr 9, 2011 02:22 PM
passaphist
May 23, 2007 02:21 AM
D83zxt
Nov 15, 2003 01:43 PM
