broken antenna
Old Jul 29, 2004 | 03:08 AM
phrozen209's Avatar
broken antenna
Hey, my antenna on my '93 300zx goes up when I turn on the stereo, but when I turn it off, the antenna goes down, but when 8-10 inches are left, it will slow down and make a noise and then at like 3-5 inches before it goes down, it stops. Is it the motor that is messed up, or just the antenna???
Old Jul 29, 2004 | 10:00 AM
91zxtt's Avatar
The mast is broken inside the antenna about 8"-10" from the top. It's common. It's fairly inexpensive and fairly easy to fix. If you can't get it from a local autoparts store, then you can get it from the dealer without getting ripped off too bad.
Old Jul 29, 2004 | 11:43 AM
CanyonCarver's Avatar
Jack Of All Trades
Buy it now, $19.99
http://cgi.ebay.com/ebaymotors/ws/eB...category=46093
Old Jul 29, 2004 | 12:09 PM
phrozen209's Avatar
cool! i thought it was the motor that was broken! thanks guys...
Old Aug 18, 2004 | 10:58 PM
n_2_fairladyz's Avatar
recently JL'd
hey, I have the same problem... ty CanyonCarver for the ebay tip.
Old Aug 19, 2004 | 12:54 PM
phrozen209's Avatar
i have the new antenna, but i tried to take the old one out, and it wont budge... i followed the instructions, but it still dosent want to come out...
Old Aug 19, 2004 | 11:41 PM
Riz Z Speed's Avatar
Administrative Brown Guy
which part won't come out?
The motor or the old antenna mast?
if it's the motor look to make sure you have all the nuts and bolts removed that hold it in place.
If it's the mast you can't remove it by hand or just pulling on it. You have to remove the whole assembly from it's location, then while it's still powered(hooked up to the car) turn the radio on. Doing this should cause the motor to turn on and try and dispell the mast from the motor assembly. At that point while the motor is pushing you should be pulling on it. That should free the broken mast from the motor and allow you to install the new mast by reversing these steps.
crankshaft
Mar 11, 2009 12:34 PM
casandrastreet
Jun 25, 2007 05:55 AM
kevtt
Jul 11, 2006 02:24 PM
91black300zx
15
Aug 3, 2004 02:23 PM
tsefreeflow
Nov 11, 2002 05:18 PM
