Warning voice
Old 07-31-2011, 02:54 AM
86_VG30ET_Z31's Avatar
Warning voice
Got an after market radio installed but now the warning
Voice wont come on how can i make it work again
86_VG30ET_Z31 is offline
Old 07-31-2011, 10:27 AM
AZ-ZBum's Avatar
Hook up your new stereo properly.
http://www.az-zbum.com
AZ-ZBum is offline
Old 07-31-2011, 03:52 PM
I didnt install it my self a shop did it
Old 07-31-2011, 10:34 PM
AZ-ZBum's Avatar
There's your problem. They bypassed it.
AZ-ZBum is offline
Old 08-01-2011, 07:30 PM
How can i get it to
Work like it used to before if theres any way of doing it.
Old 08-01-2011, 08:58 PM
Originally Posted by 86_VG30ET_Z31
How can i get it to
dude...
and to make it even more simple, here's the exact link / quote (emphasis added to make sure you see it):
http://www.az-zbum.com/information.stereo.shtml
Originally Posted by ZBum
Voice Warning (aka Bitching Betty) (84-86 GL and GLL models only):
The voice warning only came in the 84-86 GL and GLL models. SF models and 87-89 Z31s did not have the voice warning system. It works by stopping the signals going to the front left speaker(s) and replacing it with a signal of its own. Even without a stereo in the car, the voice warning would still work if the speaker is still there and hooked up to the stock wiring. If you want to keep the voice warning, you rewire the rear speakers and use the stock front wires. The voice warning unit is located above and behind the ECU in the passenger kick panel. It's hidden by a piece of insulation. It is possible to totally rewire the stereo system and use totally new speaker wire and still retain the voice warning. There are many ways to do it. One way is to run the wires for the front left speaker to the voice warning unit speaker lead inputs. Then run the speaker lead outputs to the front left speaker. Another option is to add a dedicated speaker (any basic full range speaker will work) and simply run the outputs to this speaker.
NismoPick is offline
Old 08-01-2011, 09:26 PM
Thanks
Old 08-01-2011, 11:27 PM
AZ-ZBum's Avatar
Why do I get the feeling it's like I'm talking to a brick wall? Why didn't you click the link and read it? Do you think I posted it for the **** of it?
AZ-ZBum is offline
Old 08-02-2011, 03:19 AM
I was reading it throu my phone couldnt see the link until i checked it out on my pc was i able to acess the link
Mfhoel
08-14-2013 02:02 PM
maxxypearl
08-21-2009 04:06 PM
BADASSTT
10-24-2008 02:13 PM
TMan
03-30-2003 06:02 PM
ZorroZ
03-20-2003 11:42 AM
Quick Reply: Warning voice
