Warning voice
Got an after market radio installed but now the warning
Voice wont come on how can i make it work again |
I didnt install it my self a shop did it
There's your problem. They bypassed it.
How can i get it to
Work like it used to before if theres any way of doing it. |
Originally Posted by 86_VG30ET_Z31
(Post 298678)
How can i get it to
Work like it used to before if theres any way of doing it. http://www.az-zbum.com/information.stereo.shtml
Originally Posted by ZBum
Voice Warning (aka Bitching Betty) (84-86 GL and GLL models only):
The voice warning only came in the 84-86 GL and GLL models. SF models and 87-89 Z31s did not have the voice warning system. It works by stopping the signals going to the front left speaker(s) and replacing it with a signal of its own. Even without a stereo in the car, the voice warning would still work if the speaker is still there and hooked up to the stock wiring. If you want to keep the voice warning, you rewire the rear speakers and use the stock front wires. The voice warning unit is located above and behind the ECU in the passenger kick panel. It's hidden by a piece of insulation. It is possible to totally rewire the stereo system and use totally new speaker wire and still retain the voice warning. There are many ways to do it. One way is to run the wires for the front left speaker to the voice warning unit speaker lead inputs. Then run the speaker lead outputs to the front left speaker. Another option is to add a dedicated speaker (any basic full range speaker will work) and simply run the outputs to this speaker. |
Thanks
Why do I get the feeling it's like I'm talking to a brick wall? Why didn't you click the link and read it? Do you think I posted it for the **** of it?
I was reading it throu my phone couldnt see the link until i checked it out on my pc was i able to acess the link
