Turbo Question
Old Nov 17, 2010 | 12:44 AM
Flacster's Avatar
Turbo Question
So question. can a larger engine handle more boost? example. stock boost for vg30et is 6.8. can a vg33 handle a safer higher boost 10 perhaps and still be as safe as the vg30et? thanks
Old Nov 17, 2010 | 01:31 AM
oh my god.............
Old Nov 17, 2010 | 06:50 AM
Spot on! These are the turbos for a VG33:
Old Nov 17, 2010 | 07:09 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
Stronger internals = safer higher boost. You could probably sleep well at night if you didn't boost higher than 10psi.
Learn: Size doesn't matter.
Unless you want higher boost, then you need a bigger turbo...
tumblr_l7p7tl5wia1qzlin0o1_500.jpg?t=1290035202
Old Nov 17, 2010 | 07:54 AM
lulz.
Old Nov 17, 2010 | 10:49 PM
It has nothing to do with the strength of the internals, it has to do with the tune and the size of the turbo!
Old Nov 17, 2010 | 11:20 PM
Oh fer realz!!!! Ima go build a 1000hp motor outta balsa wood then! I just gotta tune it right!
Old Nov 18, 2010 | 12:37 AM
lmao, you know what I meant...
Old Nov 18, 2010 | 01:11 AM
maybe I did... but balsa wood is way to funny to not use in a ridiculous rhetorical situation.
But more realistic, internals strength will become an issue no matter what the tune after certain limits. On these old 80's motors, a completely stock motor I would say 10psi max, MLS HG it and ARP heat stud it, you could go up to 20 if the motor is otherwise healthy and then yes at this point a very good tune high octane and then we are getting into meth injection territory as well. But the longevity of that motor even tuned well is in question, and wouldn't compare to a built motor with good forged internals and such.
In my personal opinion, ANY motor should be able to take 10psi though from teh factory if tuned well. any any any.
When I see stock S2000 blocks with absolutely nothing done to them engine wise other than ARP head studs handle 30+lbs of boost and put down over 700RWP with an 11.5:1 compression ratio and a 9k rpm redline, I believe anything can handle moderate boost levels.
all be-it those motors only last 20,000-ish miles once they start seeing over 500whp... still pretty damn impressive.
Oh and to the OP, displacement has ZERO impact on ability to handle more boost. More displacement though at the same level of boost as a motor with less displacement will, or at least should, create more power and torque. Just incase the extreme levels of sarcasm in everyone's responses didn't get that point across
Old Nov 18, 2010 | 10:54 AM
domsgarage's Avatar
Tough Guy
what if you wrap your turbo in stickers?
Old Nov 18, 2010 | 01:46 PM
Where talking VG's here snw, I've seen stock long blocks take upwards of 20psi without a problem. Even the dett's are good to about 650-700WHP before you need to start worrying about hardware issues. The longevity of a modded motor depends completely on the tune and maintenance.
Old Nov 18, 2010 | 10:19 PM
I'd update the head studs on any motor going after more than 15 psi regardless of how new it is, cause a slight stretch will destroy a composite HG. if it had a factory MLS HG then fair enough... you could get away with it. And no i am not saying it is necessary, but it's a safe and good idea.
Old Nov 18, 2010 | 10:54 PM
Flacster's Avatar
question has been answered >.>
Old Nov 19, 2010 | 12:41 PM
Fair enough.
Old Nov 20, 2010 | 07:12 PM
When? Where? In this thread?
I hope it wasn't the sticker wrapped turbo that answered your question.
Old Nov 20, 2010 | 11:34 PM
My post answered it, I'm all for teasing someone, but gotta five em a somewhat straight answer, not everyone picks up on internet sarcasm :P
one_fast_300zx
Oct 22, 2006 01:14 AM
deedee
Jul 14, 2005 02:03 PM
ZWatcher
Aug 23, 2003 04:33 PM
z17
Sep 7, 2002 02:57 PM
Simonissan
Jul 20, 2002 05:50 PM
