tranny probs
Old Sep 16, 2008 | 02:23 PM
Zphillips's Avatar
Unhappy tranny probs
i have a 85 300zx non turbo, when put into low gear it goes into low and reverse, the same with park, it feels like it's in reverse and park. when in drive car starts out in drive gear not first. but when driving highway speeds it will go in and out of overdrive, any answers??????
Old Sep 16, 2008 | 02:24 PM
Zphillips's Avatar
tranny problems
Old Sep 16, 2008 | 02:59 PM
Your post is pretty hard to understand... but welcome to ZDriver! Have you checked the ATF level?
Old Sep 17, 2008 | 10:26 AM
mikebuhrZ's Avatar
after you check the level...change the fluid,the filter plugs easily on the 4n71b trans.. DO NOT FLUSH THE TRANSMISSION!!... this will lead to certain death of the trans
Old Sep 17, 2008 | 02:39 PM
lifegrddude's Avatar
Externally Wastegated
Sounds like you might have some slop in the linkage too. Also, please use better punctuation. It'd make what you're trying to say a little easier to understand.
Old Sep 17, 2008 | 05:04 PM
Zphillips's Avatar
I did a filter and oil change, can you think of anything else?
Old Sep 17, 2008 | 05:09 PM
Do you mean ENGINE oil and filter, or TRANSMISSION fluid (ATF) and filter?
Old Sep 17, 2008 | 05:57 PM
turboboost's Avatar
Dur, aren't they the same thing?
Old Sep 17, 2008 | 07:07 PM
Zphillips's Avatar
transmission filter and oil
Old Sep 17, 2008 | 07:19 PM
Ah... not to get technical, but we call transmission oil "fluid" as it's quite different than engine oil. Did you use ATF (red auto trans fluid) ?
Old Sep 17, 2008 | 07:30 PM
Zphillips's Avatar
yes I did, I have a 78 280 that I did a frame off restoration myself. I'm not a automatic tranny guy,anything else but autos
Old Sep 18, 2008 | 09:19 AM
RocknTommy's Avatar
When you do a total fluid change, especially in a high mileage automatic transmission, the detergents will clean off all of the build up that is needed to hold that puppy together. Once all the gunk gets cleaned off from these detergents, things start to go south fast. There is also a temperature sensor that will not allow the car to go into overdrive until the transmission has warmed up. They get quirky from time to time too.
Old Sep 22, 2008 | 06:37 PM
84z31nonturbo's Avatar
What is wrong with "flushing" the tranny, instead of just draining the fluid and putting new in? The flush takes the fluid out of the tourqe converter as well as whats just setting in the tranny.
Old Sep 22, 2008 | 10:04 PM
I guess you missed that last post by RocknTommy.
Old Sep 23, 2008 | 01:02 AM
entropy31's Avatar
The Cake Is A Lie!
z31 autos were not known for their reliability. the tranny in my '87 auto went to hell at about 185k. how many miles are on your car? it might just be time for a new transmission.
Old Sep 23, 2008 | 08:07 PM
yeah, 85T auto tranny's also dont like 7300 RPMS neutral drops either.. who woulda' thought?
Old Sep 25, 2008 | 06:02 AM
Zphillips's Avatar
does any one have a 85 300zx automatic tranny for sale.?????
Seattle_Max
Dec 3, 2013 06:42 PM
JonDavidF
Mar 5, 2005 04:22 PM
Z-er
Jan 24, 2004 05:11 AM
burlz33
Sep 17, 2002 03:29 PM
duckyz
Sep 4, 2002 07:42 PM
