tranny probs
i have a 85 300zx non turbo, when put into low gear it goes into low and reverse, the same with park, it feels like it's in reverse and park. when in drive car starts out in drive gear not first. but when driving highway speeds it will go in and out of overdrive, any answers??????
When you do a total fluid change, especially in a high mileage automatic transmission, the detergents will clean off all of the build up that is needed to hold that puppy together. Once all the gunk gets cleaned off from these detergents, things start to go south fast. There is also a temperature sensor that will not allow the car to go into overdrive until the transmission has warmed up. They get quirky from time to time too.
Originally Posted by mikebuhrZ
after you check the level...change the fluid,the filter plugs easily on the 4n71b trans.. DO NOT FLUSH THE TRANSMISSION!!... this will lead to certain death of the trans
