Ticking with my 85
Old Mar 16, 2006 | 01:48 PM
Andross's Avatar
Ticking with my 85
My '85 300zx has been doing this for a while and I dont know what it could be. when it has been driven for a little while it makes this ticking noise. That harder I drive the louder the sound. When I change or add oil the sound stops for a little while. First it was months before it would return, now it's weeks... anyone know what it might be?
Old Mar 16, 2006 | 02:01 PM
Could be tons of things.... could ya be more specific? Like.... what area the tick is coming from.... is it loud.... quiet.... metal scraping sound?
Old Mar 16, 2006 | 02:04 PM
Andross's Avatar
No, not metal scraping and the faster I drive the louder it gets during idle. the speed of the tick also increases at higher RPMs. I'm not sure where it's coming from other than under the hood.
Old Mar 16, 2006 | 09:02 PM
FreeLanceBum's Avatar
Sounds like your valve lifters.
Old Mar 16, 2006 | 10:29 PM
duowing's Avatar
NisTuner
I've also heard that the fuel injectors will tick. As they get older they aren't as quiet and I guess as it sprays fuel, you'll be hearing that, although I could be completely wrong.
Old Mar 17, 2006 | 11:53 AM
jfairladyz's Avatar
Yeah the injector click as well. But if you listen carefully you can usually tell if it's the injectors or not.
Old Mar 17, 2006 | 06:30 PM
91Zman's Avatar
Opinionated
sounds like it might be lifters
Old Mar 17, 2006 | 09:48 PM
Since it's an overhead cam, I'm gunna say it's not the lifters
Could be the ROCKERS... they do make a clacking sound (when not adjusted correctly) that increases w/ rpms.... but there are no LIFTERS in the VG30.
Old Mar 17, 2006 | 09:52 PM
jfairladyz's Avatar
Actually the VG30 DOES have lifters
Old Mar 17, 2006 | 09:55 PM
oh yes yes... thas what I meant to say.
Old Mar 18, 2006 | 12:22 AM
The VG30 has hydraulic lifters(they automaticly adjust themselves), these can get pretty dirty and glogged up with age and lots of miles. When they do get blocked up, oil will not pass through then as it should, and wont allow for the adjustment, thus the clicking from a lack of a cushion of oil.
If it is the lifters and not the injectors that is.
Old Mar 18, 2006 | 05:09 PM
jfairladyz's Avatar
Here's a link to cleaning hydraulic lifters. It's not specific to our cars but the practice is the same.
http://www.atlanticz.ca/zclub/techti...r+cleaning.pdf
Old Mar 19, 2006 | 04:33 AM
WolfMan's Avatar
link does not work......
Old Mar 19, 2006 | 09:02 AM
Worked for me.
Old Mar 19, 2006 | 06:09 PM
jfairladyz's Avatar
You have to have Adobe. It's a PDF page. If you're running an older version it may just be slow or you may need to update Other than that it should work.
Old Mar 19, 2006 | 08:13 PM
Andross... any way that you can record the sound & put it on ya comp? Maybe w/ a camcorder or digi-cam? I think if we heard the sound, it would be easier to tell what ya mean.
Old Mar 19, 2006 | 09:00 PM
jfairladyz's Avatar
A piece of vacuum hose will tell you where the sound is coming from
theatriks
Oct 1, 2013 10:05 AM
Love2ridepow
Aug 2, 2006 08:24 AM
allmotor300z
20
Mar 11, 2005 10:32 PM
chukker
Oct 4, 2003 04:53 AM
Dark_Ryder
Dec 18, 2001 01:08 PM
