ticking comming from clutch...
Old Nov 18, 2006 | 05:25 PM
there seems to be a fairly noticable tick when the clutch is out, but when there is the slightest pressure on the pedal it goes away..its pretty weird, any suggestions?
Old Nov 18, 2006 | 05:47 PM
Could be the throw out bearing. Tho, can you feel it in the shifter?
Old Nov 18, 2006 | 07:31 PM
nope, shifter needs bushings though..
Old Nov 18, 2006 | 11:44 PM
i was thinking throw out bearing.. carefull with those throw out bearings... if they fail it can be catastrophic. my buddies failed... shattered and destroyed his whole clutch/flywheel assembly... than again... it was in a B18c4 (GSR motor) in a civic
Old Nov 19, 2006 | 02:15 PM
if i end up replacing the clutch, im also doing a fidanza flywheel as well..
theatriks
Oct 1, 2013 10:05 AM
Monkies
May 18, 2011 06:35 PM
Andross
16
Mar 19, 2006 09:00 PM
chukker
Oct 4, 2003 04:53 AM
