Speedo Pinion Gear Removal (how to)
Old Mar 1, 2007 | 03:52 PM
RedZCar's Avatar
Anyone know how to remove the speedo's pinion gear and replace it? I think that might be my issue with my speedo reading the speed only on occasion.
Old Mar 2, 2007 | 03:31 AM
TBK1's Avatar
pretty easy, remove the one bolt that holds the retainer clip on and then wiggle/turn it back and forth as you pull it out. But would bet thats not the problem, either end of the cable could be slid out just a touch or the ends rounded (instead of flat) or binding inthe cable sleeve.
Old Mar 2, 2007 | 03:58 AM
RedZCar's Avatar
well... as stated in my other post... the digital gauge (86 auto n/a w/ digi dash) will read zero from time to time. When I say time to time I dont mean for a little bit. It can be like an hour without sign of a real speed. I replaced the speedo cable and the speed sensor. I've double checked the connection on both ends of the speedometer cable and they're good too. I can't imagine both cable's being rounded off. Any other ideas still would be greatly appreciated.
When the speedo goes to zero here are some other things that happen:
- Acts as if the kick down pedal no longer works (wont downshift for speed... but will when I decelerate)
- My "G" meter (which tell's how much of a "gangsta" I am... lol j/k) goes to zero.
- My car loses a little pep (probably related to the lack of downshift)
- My odometer stops working
- my gas milage gauge stops working (reads zero or a really high number ... aka 97mpg)
Keep the ideas coming i really appreciate it
Old Mar 2, 2007 | 05:01 AM
TBK1's Avatar
I'm really a 1st gen guy but sure sounds to me like an electrical prob and I would have no idea where to start!
Old Mar 2, 2007 | 06:15 AM
RedZCar's Avatar
yeah... I'm afraid its electrical too... this is easier to fix so I thought I'd try it first. Anyone know where to look if it is electrical?
Monkies
Jul 29, 2013 09:35 PM
pnoyslimm
Jul 2, 2013 08:07 PM
Evan Faris
Jun 3, 2013 06:19 AM
PredatorZ
Apr 12, 2013 03:04 PM
SHADY280
Jul 8, 2005 03:49 PM
