High beams
Old Oct 10, 2005 | 03:02 PM
drummer69's Avatar
High beams
Help me, I have a problem with my lights, when I flip on the highbeams, the right lamp goes out completely, with the left working highbeam. I replaced the 3 prong plug, still no success .
Old Oct 10, 2005 | 04:15 PM
melloyello's Avatar
It's a problem in your dimmer switch more than likely. Just do what I did and run a wire from the left side to the right so both come on no matter what. Might not be the right way to do it but it works.
Old Oct 10, 2005 | 05:12 PM
drummer69's Avatar
where is the dimmer switch ? is it on the headlamp itself ?
Old Oct 10, 2005 | 05:18 PM
drummer69's Avatar
is that under the hood or the dash ?
Old Oct 10, 2005 | 06:24 PM
AZ-ZBum's Avatar
it's most likely a problem with the headlight switch itself. the dimmer switch controls the brightness of the dash lights. has nothing to do with the main headlights.
Old Oct 10, 2005 | 07:07 PM
drummer69's Avatar
how would I repair something like that, the switch actually works the left lamp for the highbeams, why not the right, is it easy to remove the headlight switch on an 85 300zx ?
Old Oct 11, 2005 | 01:32 AM
AZ-ZBum's Avatar
if you took 30 seconds to look at the switch, you'd understand why you're asking a stupid question.
Old Oct 11, 2005 | 01:39 AM
Velox ZX's Avatar
From: I'm located in the more southern local... Jackson, MS.
LOL.... check your headlight relays, infront of the passenger side strut tower, behind the passenger side headlight.
JD
Old Oct 11, 2005 | 09:18 AM
AZ-ZBum's Avatar
JD
I challenge you to find the headlight relays. Show me a wiring diagram that shows them. Show me a diagram that shows where they are.
Old Oct 11, 2005 | 04:32 PM
melloyello's Avatar
When I said dimmer switch I meant the headlight dimmer switch, duh.
Old Oct 12, 2005 | 12:06 AM
AZ-ZBum's Avatar
headlights don't have a dimmer switch. they have high and low beams.
mymelzx
Jul 3, 2012 01:22 AM
82zxturbo
Nov 1, 2007 06:32 PM
jjohart
Mar 28, 2006 10:12 AM
reyazul
Sep 8, 2002 03:06 PM
nissan1990
May 7, 2002 09:33 AM
